Results 1 to 8 of 8
    May contain nuts
    Reputation: Haggis's Avatar
    Thomson layback - not enough tilt adjustment?
    Anyone else have problems with insufficient range of adjustment to get saddle level on the layback post?
    Front bolt bottomed out...
    Is there another top clamp avail with more front clearance for slacker seat tubes/less than horizontal saddle rails?
    g3h6o3
    Reputation: PissedOffCil's Avatar
    Oct 2007
    I remember it was a close fit for me and I thought it was badly designed... A new top clamp will not help if you bottomed out the bolt, you would need a bottom clamp with an angle.
    One way or another they don't exist as far as I know but Thomson are very responsive to e-mails so ask them directly.
    Check out my SportTracks plugins for some training aid software.
    1*14*29*2.1 & 1*1*29*2.4
    mine was fine...73deg STA . What is your STA?
    Reputation: Bailey44's Avatar
    Dec 2010
    Mine was fine with a 72deg STA.
    Reputation: SlowPokePete's Avatar
    Mar 2006
    Make sure the top piece of the clamp isn't reversed...
    SPP
    Rigid.
    May contain nuts
    Actual STA is 69.5deg, effective 74deg
    g3h6o3
    Oct 2007
    I can see that being a problem!
    Drinkin' the 29er KoolAid
    Reputation: kwarwick's Avatar
    As you've probably noted, saddles with seat rails that are closer to horizontal make the problem worse. WTB saddles seem to be common offenders in this area. If you're not terribly attached to your current saddle, see if you can find one with more more angle in the seat rails.
  1. Shoes with built-in varus tilt
    By wankel in forum Apparel and Protection
    Last Post: 08-09-2012, 01:13 PM
  2. Layback post or straight ?
    By juanverde in forum 29er Components
    Last Post: 06-14-2012, 09:30 AM
  3. advice please! - seat tilt
    By mforness3000 in forum General Discussion
    Last Post: 11-04-2011, 04:52 AM
  4. Replies: 4
    Last Post: 08-19-2011, 07:30 AM
  5. racer X Seatpost? Layback or inline
    By the_pilot in forum Titus
    Last Post: 05-24-2011, 02:09 AM
