Results 1 to 12 of 12
    Reputation: toot334455's Avatar
    Apr 2013
    Is there somthing wrong with this?
    I've got inferno 23's with stans strip running Schwalbe racing ralphs and they are terrible.
    No traction wipped out 3 times today.
    They are ran at around 25 psi.
    I would rather run my nevagals with Tubes at 40 PSI than this.
    I weigh 220 lbs, does this have anything to do with this?
    Is there a point where if you weigh above x amount tubless doesnt work?
    OR is it my setup not being "True Tubless"?
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by toot334455 View Post
    Being use to Nevegals, and at your weight you may need to use more pressure and learn how they handle. The RaRa does not handle the same or have as aggressive tread.
    mtbtires.com
    Apr 2013
    Quote Originally Posted by shiggy View Post
    I just came back from the garage and pumped them up to 35 psi.
    Its like at the lower psi the whole tire rolls on its side wall and I get no traction.
    Tires should have weight ratings.
    Before the nevs, I hate slant six's which were terrible for my weight.
    And after comparing the slant six's and the racing ralph's they look very similar.
    I'm going to a different traill tommorow that's not so technical so maybe ill get a better feel for the.
    DFMBA.org
    Reputation: MTBeing's Avatar
    Honestly, 25 psi at 220 lbs is a bit optimistic. Just up your pressures until you feel a compliant ride without the roll-out issues.
    Take a pump with you and modify your settings as you go.
    Please donate to IMBA or your local IMBA chapter. It's trail karma.
    Those tires are fast, but they may not be aggressive enough for your style of riding and terrain. If you still are washing out go to a Nobby Nic on the front. More grip means more curve speed and almost as fast in the straight-- just not.
    Apr 2013
    I def. Have the " roll-the-tire-into-the-lean riding style".
    I have a nobby nic up front RR in the rear.
    Both were acting up.
    I put some air in the nobby after biting it hard. and it seemed to be fine after that.
    Im really afraid the RR just doesnt have enough tread on it for me.
    It keep washing out.
    It doesn't help that I changed from nev's to these.
    Also the nobby nic seems like it should go in the opposite direction than the suggested direction on the tire.
    WillWorkForTrail
    Jun 2012
    RaRa's can definitely be a little skittish. If you're 220, try running them around 29 PSI in the front, and 32 in back. Then just remember they aren't going to hang on as well as something like Nevs. They do pretty good straight dirt that's semi hard pack, but if you put a sprinkling of rocks across the top, forget it. They are just a really fast racing tire, meant for really fast XC racing trails.
    Apr 2013
    Quote Originally Posted by Cotharyus View Post
    One of the spot was a tight downhill switch back with a light layer of fine gravel.... thanks for the warning about that. Seems like this is the type of tire you put on just for races and when your extremley confident in the trail
    turtles make me hot
    Reputation: NYrr496's Avatar
    I think part of the problem is the rims are too narrow. I've run Slant Sixes on 30mm rims at 30 psi and they've been great... I weigh 255.
    I build Inferno 27's for everyone as I feel the 23's are too narrow for the 2.25 and up tires.
    I like turtles
    Reputation: Peddlin' Fool's Avatar
    Jul 2013
    I came across this Tech Tip regarding Tire pressure..,
    To determine a starting tire pressure when running NoTubes tires, use this simple formula.
    Rider Weight in pounds divided by 7 = x
    x - 1 = Front tire pressure in PSI
    x + 2 = Rear tire pressure in PSI
    220 / 7 = 31.4. So in your case, 30.4 PSI in the front, 33.4 PSI in the rear.
    Hope this helps!
    Apr 2013
    Nice ill try that tip.
    I just got down riding through the neighborhood with them up around 40 and they felt way better.
    Some confidence is getting built there.
    This psi thing might be the reason why I didnt like the s6's.
    There is a huge lack of side knobs on those though as well.
    Apr 2013
    It worked... these tires are insane!
    This time I almost wiped out because of too much speed in spots I usually dont get.
    Thanks for the help!
  1. This is just wrong!
    By wvmtb in forum Passion
    Last Post: 05-23-2012, 11:34 AM
  2. Cannondale RZ one forty 3Z or somthing else for $2000?
    By BritOnTour in forum Bike and Frame discussion
    Last Post: 01-27-2012, 07:50 AM
  3. cx- i'm doing it wrong
    By rowdstar in forum Cyclocross
    Last Post: 10-25-2011, 06:40 PM
  4. Replies: 9
    Last Post: 09-08-2011, 03:50 AM
