    It's all ball bearings
    Reputation: gopriest31's Avatar
    Sep 2004
    Switching Shimano sl- m-670 front shifter from 3 to 2 speed setting
    Looking for a clue here. Have a 12' model shimano front shifter slx model sl m-670 that came stock on my Santa Cruz tallboy. I understand this shifter can be switched from 3 to 2 speed setting and will work for either. How do you do this? Any help would be appreciated, looking to go to 2x10, currently in 3 speed mode
    Reputation: bigkat273's Avatar
    Look at the underside of the front shift pod, there should be a switch labeled 3x/2x. Just push it on over.
    Plays with tools
    Reputation: customfab's Avatar
    Quote Originally Posted by bigkat273 View Post
    You can only do this when all of the cable is out.
    Re: Switching Shimano sl- m-670 front shifter from 3 to 2 speed setting
    Ah yes forgot to add that in... Good catch.
  1. 10 Speed 3x shifter with 9 speed front derailluer
    By Hiebs915 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-03-2013, 08:29 PM
  2. will 2x10 shimano m980 xtr front shifter work with sram xx front derailleur?
    By gideon in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-01-2012, 06:28 AM
  3. Replies: 2
    Last Post: 06-23-2012, 12:40 PM
  4. Shimano 3-speed front shifter compatible with all series?
    By r1Gel in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-16-2012, 08:36 AM
  5. Replies: 1
    Last Post: 02-14-2012, 06:40 AM
