Results 1 to 3 of 3
    swapped pedals but something feels off?
    OK I just switched from SPD to TIME ATAC and I am loving the pedals but since the switch I feel that something is just a bit off. I can't pinpoint it but I'm wondering if it's not saddle height.
    anybody know the difference in stack height between the pedals? I guess I could measure them but wondered if anyone had actual numbers on-hand. not sure if I need to move the saddle one way or the other but I'm guessing it needs to go down a few mm.
    Thanks for any input you might have
    Shawn
    Basement Dweller
    Reputation: JosefFritzl's Avatar
    Did you make sure they were 29-er compatible?
    thank you. I knew I forgot to check something!
    so on that helpful note... stack height is very similar with the SPD being slightly larger. so a small drop in saddle is possibly warranted but in doing my regular maintenance i was checking pressures and torques and noticed my rear shock was down by 40 psi. not sure the reason but I topped it off and I'm willing to bet problem solved.
