Results 1 to 23 of 23
    Reputation: Ronnie's Avatar
    Sunrace CSM99 9-Speed 11-36T Cassette.
    I recently posted this following in the Drivetrain Forum and didn't get too much response so I thought I'd post it here as well. I know that there are quite a few people who have said they still use 9 speed drivetrains and would like lower gearing for a 29" bike.
    I used to live in New Jersey and was perfectly happy with my Shimano XT 11-34T cassette on my 29" hardtail. A few months ago I moved to Northern California where the climbs are extended and can be a few thousand feet straight up. I'd prefer not to replace my entire drivetrain so I've been looking for a 36T 9 speed cassette and came across the Sunrace CSM99 on Amazon.
    These are the claimed specs. for this cassette:
    11-36 9 Speed cassette featuring a nickel plated finish
    Black anodized aluminum spider composite spacers and aluminum lockring
    Gear Combination 11-13-15-18-21-24-28-32-36
    Weight 390 grams
    Chain compatibility 6.6mm
    Out of curiosity I went ahead and ordered one and I'm a bit disappointed but maybe I'm being a bit neurotic. I don't want to destroy my aluminum freehub.
    The claim that it has an aluminum spider may be a bit misleading. only the first three cogs are on the spider. The rest are single cogs with spacers in between except for the 11T and 13T which are one piece.
    If anyone has used one of these I'd appreciate any input as it looks promising, if it works well and doesn't destroy the freehub body.
    The trouble with having an open mind is that people will insist on trying to put things in it.
    Feb 2006
    Isn't that the same configuration as XT or XTR? First three or four and then loose. I would try it. Go for a ride around the block and check it.
    Jan 2014
    my road cassettes are all like that. Also, please report back on your riding impressions. I'm looking at this cassette or spending big bucks and converting to 10 speed with the oneup 42T conversion
    Fat-tired Roadie
    Nov 2007
    I'd probably just get the Shimano 11-36 cassette. Is your freehub available in steel?
    Reputation: watts888's Avatar
    Oct 2012
    The carrier is really important on the large rings because of the torque. One reason I'm reluctant to do the 42T conversion. The smaller cogs could get away without being on a carrier, although I'd still be reluctant to use it on an alloy hub. I checked the gear ratios, and I decided to get the 11-34 HG51 shimano cassette. Not enough of a benefit to justify the higher cost for the sunrace cassette. I'd considered the 12-36 shimano 9-speed cassette, but for some reason it's much much more expensive than their 11-34T. Basically, the same as a 10-speed cassete.
    Quote Originally Posted by Fred Smedley View Post
    No, The XT has the first "six" cogs attached to the spider.
    http://techdocs.shimano.com/media/te...9830625614.pdf
    Quote Originally Posted by AndrwSwitch View Post
    Unfortunately no I can't get a steel freehub and I know that the Shimano HG61 eats aluminium freehubs.
    Quote Originally Posted by watts888 View Post
    You can get the Shimano HG61 cassette for $42 from places like Universal Cycles:
    Universal Cycles -- Shimano CS-HG61 9sp Cassette
    but as I said it chews up aluminum freehubs.
    I thought that I should report back on a problem I had with this cassette before someone else went to the trouble of getting one. Today I took the trouble to fit it and could not complete the job. The machining of the last (11 tooth) cog that goes over the end of the freehub body was very poor and would not fit properly.
    So back it goes.
    ballbuster
    Reputation: pimpbot's Avatar
    Quote Originally Posted by Ronnie View Post
    So back it goes.
    Use a road bike style spacer behind the cassette. THat is the thin little washer that is cut out the same shape as the Shimano freehub body. This is a common issue with road bike freehubs and cassettes.
    But yeah, it's going to be a while before I give up my 9 speed. I'm running Dual Control levers, and love them... but, they dropped it before going 10 speed.
    I would love to get a 36t big cog I can use with an alu freeub body.
    Reputation: johnbike81's Avatar
    May 2013
    Re: Sunrace CSM99 9-Speed 11-36T Cassette.
    I got the sunrace 11-36 awhile ago and it has been great.
    Sent from my LT30at using Tapatalk 2
    Quote Originally Posted by pimpbot View Post
    I don't understand what you're trying to say. Surely that spacer would move the cassette outboard. I fitted the thing and it looked fine. It even worked fine in the stand, without making any adjustments, until I changed into the 11T cog. The chain jammed up against the chain stay and wouldn't go onto the cog. I took the cassette of and noticed that the slots that fit over the end of the splines were very badly cut and would not fit properly so the cog was too far outboard. If it doesn't fit right, I don't want it.
    I had dual control on my XTR M960 group and thought it was great (at first) but had a few scares when the brake lever disappeared out of my hand in the rough and gave it up. One reason I don't want to give up my 9 speed though is rapid rise. I love going into a bigger gear with my thumb on both shifters.
    That's nice that finally there is another option, but it doesn't sound like a great one.
    And the Shimano HG-61 12-36 cassette has no carrier and weighs around 423g. I had hoped that a carrier style cassette would have saved more weight.
    On wuss patrol
    Reputation: Glide the Clyde's Avatar
    Digging this up.
    I recently purchased an M99 based on a recommendation. That individual's M99 looked and performed very close to a Shimano XT-level cassette, 5-point carrier with the 6 lowest gears mounted on it.
    To order and receive this M99 with the 3-gear carrier and poorer quality than either S co., I am a bit disappointed. I was planning to use this cassette on a new Stan's Flow with an alloy free hub body and was expecting the 6-gear carrier to prevent more gears from digging into the alloy.
    Btw, other than the Shimano HG61 with all separate gears and this Sunrace, no one makes a 9-speed 11-36 or 12-36. There are no quality 9-sp 36 tooth cassettes available.
    Anyone with the Sunrace on an alloy FHB with good results? I haven't mounted it on the wheel yet so I don't know if I'll have the same 11-t problem that Ronnie did.
    Sometimes, you need to go fast enough that the trail is a blur to find clarity. -- Wild Bill
    Reputation: BMC FS's Avatar
    Dec 2011
    Quote Originally Posted by Glide the Clyde View Post
    Digging this up.
    @ Clyde
    Did you get this mounted yet and take it for a test run?
    On wuss patrol
    @BMC: it's mounted on the free hub and fits fine but the wheel is not on the bike yet
    Sep 2013
    I hope it will work, because I'm count on this cassette....
    Dec 2011
    Well, it works. I don't feel it shifts as clean as my xt or xo did. It also had a little ghost shifting but that may be due to me not using a new chain. I'm also not a fan of the super shiny chainrings, looks cheap. It seams like the spider they used for the 3 large rings made it weigh more than just being separate rings. I guess it'll have to do until I can afford a new 10 speed drivetrain. I do like having the 36 tooth for some climbs.
    On wuss patrol
    Yep, it works, and it works fairly well. Probably a good value. Shifting is smooth, quiet.
    My biggest concern is the 6 highest gears digging into the fh body. When they do, I will somehow pry them off and Stan's will send me a steel one at no cost. All good.
    Feb 2016
    I just had one fail on me, the 3rd and 2nd smallest sprockets on it are all bent up. Also some of the bigger rings have some damage too. I ride in the winter and I don't know if the cold affected this Sunrace freewheel. Just got a Shimano Alivio HG400 9 Speed MTB Cassette to replace it. Hopefully it fares better.
    Sep 2014
    I had never heard of a 9 speed cassette that was 11-36 until stumbling on this post. Are they still around?
    Dec 2011
    Jan
    Jan is offline
  1. Will an 8 speed rear derailleur work with a 9 speed shifter and cassette?
    By CyclesnIPAs in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-31-2017, 04:35 PM
  2. Sram TYPE 2 10-Speed Rear Derailleur with 9-Speed cassette + -speed Gripshift
    By jaxson in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-02-2014, 09:43 AM
  3. I'm looking for opinions on the Sunrace CSM99 9-Speed 11-36T Cassette.
    By Ronnie in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-22-2014, 05:07 PM
  4. Will XT M772 rear der. 9 speed work with 8 speed shifter/cassette?
    By jh_on_the_cape in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-08-2013, 06:40 AM
  5. 9 Speed MTB Shifters + Cassette, 10 Speed Road Rear Deraileur....??
    By joehspicer@msn.com in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-09-2012, 08:42 PM
