Results 1 to 14 of 14
    Aug 2017
    Strongest Bontrager 29" wheelset
    I have a new Trek Procaliber 6 with the boost 148 rear and boost 110 front thru axle hubs running duster elite rims. I have only a few rides on them, but I am just back into riding and am a known wheel killer(no flow) and I just don't think these wheels will hold up. I am a Clydesdale and these are a little too much lightweight/race for me. Durability/strength over all else works best for me. I prefer to keep it in the family that is why I am asking for Bontrager wheels. Since I have been out of the loop for a few years I figure more people here know what is going to work for me over random internet searches.
    So what are their strongest Bontrager 29er wheels with front and rear through axles for boost 110/148? I prefer strength over weight and center lock discs is what I have now, but it is not a deal breaker.
    Thanks in advance
    Dt350 hubs with 36t ratchets will give you good longevity at a reasonable price. Wtb Asym i35 rims with Sapim Lasers pokes will build up light and strong. Sapim Race spokes if you're heavy. Nothing Bontrager will match up for the money. You can run XR2 Team 2.35 tires.
    Quote Originally Posted by FTLBike View Post
    Thanks in advance
    I'm biased - Alex in the video is a friend - but they are very good wheels.
    Bontrager Line Pro Carbon wheelsets - Mtbr.com
    ƃuoɹʍ llɐ ʇno əɯɐɔ ʇɐɥʇ
    no batteries required
    Reputation: life behind bars's Avatar
    May 2014
    Chinese asymmetrical rims laced to D.T Swiss hubs.
    Nothing that's worth anything is ever easy - M. Hall
    Reputation: brent701's Avatar
    Sep 2012
    Line pro 30's are strong.
    I personally wouldn't go anything wider than a 30. I'd stay around the 26mm range and run a 2.35 front/rear tire or at least up to a 2.4 front tire.
    I have owned a few sets of Duster wheels from Trek. and I can kill them pretty fast at only 190lbs
    Too Many .
    Apr 2017
    I wouldn't overlook the Bontrager Line series. I was not a fan of the Duster Elite wheels but the Line series has been a huge improvement.
    I look at rim width from the point of working with the limits of space a frame allows and getting the most performance out of that space. Your bike will take a 2.4" tire at the rear. 30mm works for XR1 Team 2.2" tires on my Superfly 9.8. That's the largest tire I can fit. 30mm supports the 120tpi sidewall so it can crinkle down some and create a bigger footprint in certain situations. The limit is rim hits not how low the pressure can go with the tire because foldover is gone. For your bike a 35mm inner rim will let you get the most out of a 2.35" 120tpi tire like the XR2 Team 2.35". You can go even wider for a front and maybe take advantage of new 2.5 and 2.6" tires coming to market. Trek has suggested new models for the fall.
    My recommendations are all about getting the most out of your bike. Other guys have suggested skinnier rims which will work fine. Especially with tires from Maxxis or Schwalbe with less rounded profiles.
    Carbon Fan will build and ship you carbon asym rim wheels on Dt350 Boost hubs for $773.
    Apr 2016
    Maxxis did a tire write up for there new WT tires and explained the profile vs rim size
    Rims under 29mm ID were best used with tires 2.4" and smaller
    Tires 2.5 and larger along with their WT tires were best used with 30mm to 36mm (if I recall correctly) ID rims
    Use what works for the application not just what is the largest rim/tire you can fit.
    Dec 2014
    I have the older Line Elites (non-boost, 28mm inner width, 28 straight spokes, aluminum rims, 54t ratchet). I'm 200 lbs. with no gear and not the smoothest rider. Mine have been holding up really well.
    Aug 2017
    Thanks to all that replied. I have been looking at the Line wheels. I can not afford the carbon hoops though. I am looking more into the Line elite Boost as my price range. Now all I need to do is hope that my Dusters hold up until they get the Lines back in stock.
    Dec 2014
    There's some (new, take off) Line Comps on eBay right now for $300 with free shipping.
    Aug 2017
    Thanks for the heads up. But it looks like they are not front and rear boost.
    Aug 2017
    Quote Originally Posted by life behind bars View Post
    I have had a bad experience with DT Swiss hubs. I will never use them again. I will however use DT Swiss spokes whenever I can.
    Which hub and what problem?
  1. Replies: 15
    Last Post: 06-30-2015, 09:42 AM
  2. 300lb CX/Trail rider looking for Strongest Wheelset for 26er
    By Rnd0209 in forum Clydesdales/Tall Riders
    Last Post: 12-07-2011, 07:22 PM
  3. Replies: 13
    Last Post: 10-12-2011, 02:01 PM
  4. Replies: 0
    Last Post: 09-21-2011, 01:38 PM
  5. Strongest 29" tubeless wheelset for clydesdale around $500
    By megalops in forum Wheels and Tires
    Last Post: 08-31-2011, 07:42 PM
Members who have read this thread: 75
