Results 1 to 36 of 36
    Which stem to get?
    I want to change the stem out on my 29er. It's a little too blocky for my taste, and I think I can save some weight here. I like the 90mm, 10 degree specs so I want to stay with the same length and angle. I've narrowed it down to an Easton EA90 or Thomson x4. The Easton is a little lighter which is my goal, but I kind of like the looks of the Thomson better. What do you think?
    bt
    bt is offline
    Nov 2007
    thomson
    Reputation: Shalom's Avatar
    Nov 2008
    You have stated that weight is a goal. But aesthetics are clearly important too. Which do you want more? Get that one. They are both good stems.
    Quote Originally Posted by Shalom View Post
    I would say weight first, looks second, and you can throw price in there to a degree. I probably would've went with the Thomson without much thought; while looking on Amazon the Easton was around $95 and the Thomson $85 I think. But on eBay I was able to find the Easton for $60 new. Comparing that price to the normal average price of the Easton around the net makes it almost hard to pass up.
    Reputation: SlowPokePete's Avatar
    Mar 2006
    Quote Originally Posted by bt View Post
    thomson
    Yup.
    SPP
    Rigid.
    Sep 2012
    thomson
    yes sir
    is turning a big gear
    Thomson.
    They are the bestest.
    Get it unlocked.
    J-Flo
    I'm shopping for stems as well. Looking at the Thomson, Point One, Ritchey WCS, and Specialized. There doesn't seem to be a weight savings with a carbon stem and not sure what if any advantage they offer. The Thomson seems tried and true and a safe, lightweight, strong choice; Specialized makes a good adjustable-angle stem.
    I Ride Bikes
    Reputation: Mazukea's Avatar
    I just ordered a Ritchey WCS C-260 stem. I hope I like it.
    Syntace F109
    what about Syntace F109's - whats the thoughts on those?
    Reputation: GrapeNutsRobot's Avatar
    Sep 2004
    I have rode a pair of 90mm thomson stems for a couple of years on two different bikes and recently went to a pair of 75mm Syntace F109 stems. Thomson stems are very well made and pretty to look at but you pay for it with extra weight.
    The Good Times are Killing me
    Reputation: Mojo Troll's Avatar
    Hope
    I like Hopes clamp to the steertube better than Thomson. Can get Hope in blingy colors as well. Best I can recall. Lighter than Thomson also. About the same price as well.
    Reputation: Trail_Blazer's Avatar
    May 2012
    any stem will work but the thomson is a keeper.
    Feb 2012
    Besides weight, look, colour, what else defines how a stem is better than the other?
    103g $30 7degree. I'm using and recommend the 80mm.
    New UNO Ultralight MTB ROAD 31.8 x 90mm Stem ,103g, Black | eBay
    Fat & Single
    Reputation: ozzybmx's Avatar
    KCNC FLYRIDE, the alu version of the SC Wing, much stronger at a slight weight penalty.
    These have been the last 5 stems i have bought, approx 25 or $40.
    50mm 94g,
    60mm 98g,
    70mm 103g,
    80mm 113g,
    90mm 119g,
    100mm 123g,
    110mm 127g,
    120mm 132g,
    130mm 139g
    Attached Thumbnails Attached Thumbnails Which stem to get?-kcnc-fly-ride.jpg
    Evil Following
    Trek 9.9 Superfly SL
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
    You will!
    May 2012
    Quote Originally Posted by Mazukea View Post
    I have the same in 70mm white 31.8 and it is great.
    It was not easy to install the handle bar into it but it worked with some man handling.
    Jan 2011
    I have a Race Face Turbine that has performed well. It is about the same weight as the Easton and looks much better IMHO.
    J-Flo
    Point One?
    Anyone using a Point One Racing stem? They are super light and look sweet. I don't have one, but only because I need a stem with a rise (and they come in 0 degrees only).
    May 2012
    I also think the flight control is wicked looking!
    I nearly went with one on my bike, but the style and shape would be out of place on my frame.
    May 2012
    Ultimately I went with the 2012 White Ritchey like the OP did since it matches my white bike so well:
    However, I like the logos on the 2011 model better, but I couldn't find a 70mm 2011 to buy anywhere.
    if u wanna be a baller...
    2013 Ibis Mojo HD Special Blend with dropper post, hope/stans wheelset and hope x2/m4 brakes
    Mar 2012
    Sexy
    I love this stem for Renthal Apex, check it out. Light at 148g 90mm long.
    Reputation: doll118's Avatar
    Renthal Apex +1 ,just put it on my CZAR, nice shape suit with the frame IMO.
    tired of THOMSON X4....EASTON RF.....etc
    I don't ride enough!
    Oct 2007
    This is the 29er forum right? Pick your flavor.
    Carbon
    Alloy
    May 2012
    Re: Which stem to get?
    Color Kits for Thompson x4 are sick!
    I had a Thomson X4 on one of my bikes for about a year and just sold it a couple of months ago. A couple of things that bugged me over time: the face-plate seemed to require a very precise alignment for it to stay tight, had it come loose and the bars roll forward on one too many rides. Second, the hex bolt size was a size too small for my 3-way 4-5-6 hex wrench. It was annoying to have to find that 3 or maybe it was a 2.5 for this stem.
    These issues grew over time, I didn't want to spend time over and over adjusting the stem but when I did adjust it I didn't want to look for the smaller size hex wrench. All my non-Thomson stems do not have these issues. The only difference is they don't look as nice.
    May 2012
    My x4 is the strongest stem I have owned has one of the strongest clamps I have used but the screw heads can be soft.
    Oct 2010
    Yup screw heads are def soft and the size of the bolts are annoying. Best stems though so have to assume there is a design reason being Thomson and all.
    Two years ago I would have gone for weight, but today....definitely looks.
    Reputation: RS VR6's Avatar
    Started with the Thomson...but needed to go lower...so on went the Syntace Flatforce.
    i hope the OP from 2 years ago comes back and checks some of our advice, this stuff aint free yak now...well, maybe it is.
    Haha...it is Halloween. I did notice the bumping of alot of dead threads today.
    Syntace F109 is my stem of choice for XC stuff. Strong, stiff hardware and very light. I use a 75 mm on my Epic, as I prefer a shorter stem.
