Results 1 to 9 of 9
    Feb 2006
    Stans ZTR Wheelset issues
    I have a Stans ZTR 3.30/ Crest Wheelset and I am finding when the wheels are in my bike the is side to side movement on the rear hub and a small amount on the front hub. The wheels feel like they click side to side. Anyone else have these issues with these hubs and know how to fix it?
    West Chester, PA
    There's no preload adjustment. So the bearings must be bad.
    Rod
    Rod is offline
    Reputation: Rod's Avatar
    Oct 2007
    I don't have that problem with my wheels. I would call Stan's. I hear they're easy to work with.
    There is not much choice between rotten apples.
    gio
    gio is offline
    Have u checked the quick release, and the lock ring that tightens the casette?
    Mar 2011
    Stans Crests
    Yes, my wifes almost new Stans Crests have a bit of side play. Local bike Expert says there is no bearing adjust. I plan to call Stans and check.
    1*14*29*2.1 & 1*1*29*2.4
    I had same thing with hope pro2 front hub. Was an issue with the internal spacer.
    Mar 2011
    Stans Crests
    Thanks folks, I will check out the spacer idea.
    I had the Same issue with my rear 3.30, talked with Stan's for a bit and found out I had a few bearings go out. The hubs are very easy to maintain if you want to just take them apart and check the internal bearings it's not to bad.
    Feb 2006
    Ok cool, thanks for the info.
    Sent from my ASUS Transformer Pad TF700T using Tapatalk HD
