    Stans Arch Rim and Bontrager XR1 Team Tires
    I'm going to be mounting up a set of Bontrager XR1 Team tires onto a set of Stan's Arch rims and was wondering if anybody has had any issues with this. I'm going to be using this set up in a 40 mile point to point race in a few weeks which isn't technical.
    I was wondering if anyone has done this setup before and had any issues with mounting the tires or fixing flats? I tried using a Specialized Renegade tire and it was extremely difficult to even get the tire on and off the rim.
    We've used the XR1, XR3 and XR4 on Stans Crest and Arch with great results.
    Monte
    Lodging & Guiding for SW Utah Trails
    http://www.vrbo.com/298759
    www.UtahMountainBikingAdventures.com
    MTBR Discounts
    Moderator Moderator
    Reputation: driver bob's Avatar
    29-3's (XR3's) on 355's. I needed tire levers to get them on, the fit was tight. Flipside is that I can run 18psi in the back (22psi F) and it's rock solid on the rim bead, no squirming, no movement, no burping.
    Thanks for the input guys. I don't know if I'm going to run that low of a psi for this race. This race is going to be fast paced, winner will average 20mph and I should be at about 15mph average for 40 miles. There will be a lot of sections where speeds hit 25-30 plus on some of the down hills.
    Have you guys ever had to fix a flat on the trail with these? Will a big air be enogh to reseat the bead? Or, will I have to put in a tube?
    I know Iím not going to win the race, but am shooting for a PR and bragging rights among friends and donít want to lose a lot of time if I do burp or flat a tire.
  1. Tubeless setup: Stans ZTR Arch rims with Bontrager valves?
    By Rumblefish29er in forum 29er Components
    Last Post: 08-13-2013, 06:41 PM
  2. Bontrager Non TLR tires on Stans Arch EX
    By JHANguyen in forum Wheels and Tires
    Last Post: 12-28-2012, 03:08 PM
  3. Bontrager rim strips or Stans on bontrager rims?
    By raven1911 in forum Wheels and Tires
    Last Post: 06-08-2012, 11:18 AM
  4. Q on Stans Arch rims & Schwalbe tires
    By awai04 in forum Wheels and Tires
    Last Post: 08-09-2011, 11:30 PM
  5. Bontrager XR3 Team tires
    By schwartz in forum Wheels and Tires
    Last Post: 09-21-2010, 07:28 AM
