Page 17 of 20 FirstFirst ... 7 13 14 15 16 17 18 19 20 LastLast
Results 401 to 425 of 477
  1. #401
    Reputation: RobRobideau's Avatar
    Oct 2012
    Quote Originally Posted by Adroit Rider View Post
    Sounds like you have 73mm bottom bracket and are not using the preload adjustment properly.
    Before installing the non drive side crank through the bottom bracket, hand tighten the knob that will sit next to the non drive side bearing when inserted. Insert spindle, do not use that 10-12mm spacer, attach the drive side and then go back to that knob thing on non drive side to remove play. That knob is called preload adjuster and is the solution to your problem.
    Thanks, but without the spacer there is still play even with the preload adjuster knob at it's maximum extension.
    Photos from mountain biking in Nepal:
    bideshibiker.blogspot.com
  2. #402
    Quote Originally Posted by RobRobideau View Post
    http://cdn.sram.com/cdn/farfuture/Ab..._cranksets.pdf
    Then 10-12mm thing is not a spacer but an elastomer to preload the bearing. Look at the instructions above. Are you using a mallet to tap the drive side on? Are you torquing to correct level?
  3. #403
    Trail Ninja
    Reputation: Varaxis's Avatar
    I have to say, that's a really impressive manual.
  4. #404
    Oct 2012
    The piece I am referring to is the piece illustrated at the base of the yellow arrow and i believe it is metal.
    Sent from my Nexus 7 using Tapatalk 2
  5. #405
    Well, just so happens that I will be in your area tomorrow afternoon and will take that defective crank off your hands for $25. Deal?
  6. #406
    Oct 2012
    Haha! In my area huh? Nepal? They actually got it fixed without any machining! I honestly have no idea what they were doing wrong, but it works fantastically now. I'll take it out on a real trail ride today, but there is a fairly steep hill(paved) on the way back home from the bike shop and I was carrying my 2-year-old son on my back. I never had to use the lowest gear. Super smooth, easy shifts, even under load.
  7. #407
    Why? Mine works great, so does the set of RobRobideau (see post above) and muzzanic and I can name a few more...
    edit: nice pics on your blog Rob!
  8. #408
    Oct 2012
    Got in a 1.5 hour trail ride with the new drivetrain and it works like a dream. Exactly what I was hoping for. Even while bouncing down bone-jarring rocky paths like this, no dropped chains or even chain slap.
    @betzel Glad you enjoyed the pics!
  9. #409
    Oct 2012
    After >80km, I lost the chain for the first time and it was my own fault. A half-inch-diameter stick found its way into the drivetrain. Here are a few pics of it mounted on my Chinese carbon 29er hard tail.
    Sent from my Nexus 7 using Tapatalk HD
  10. #410
    Reputation: vapezilla's Avatar
    Has anybody had the xx1 long enough to comment on chain wear?
  11. #411
    Rob, that's cheating and doesn't count as losing a chain in normal conditions. No, just kidding, seriously...I don't read something was damaged so lucky you! Would be a pity if you had to change de RD already....
  12. #412
    Oct 2012
    You are right, it definitely doesn't count and I am blessed not to have any damage to spokes or components!
  13. #413
    Mar 2011
    In the past sticks have been the death of RD's for me, XX1 construction seems much sturdier, which direction did the chain suck in the woodwork (did it go through RD or not)?
  14. #414
    Oct 2012
    I don't know exactly what route it took, but it ended up trapped between the spokes of the rear wheel and the rear derailleur. It took quite a bit of twisting, wiggling, and finagling to get it out. The rear derailleur had to have taken a decent hit.
  15. #415
    I'm just messing with you
    Reputation: wv_bob's Avatar
    Quote Originally Posted by Varaxis View Post
    Tech writers are expensive, thus the price on the group.
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
  16. #416
    Mar 2011
    So there is hope it wont get shredded on first contact with pine branches.
  17. #417
    Reputation: chomxxo's Avatar
    Got this funny little question that's been tickling my head for the past couple of weeks:
    What is Rotor going to do about XX1? Are they going to be able to come out with an elliptical Q-ring that will hold the chain on without a guide like SRAM's?
    I guess there are both practical and patent concerns to think about. Will Rotor (and/or all the other chainring manufacturers) be legally allowed to copy the tooth design that makes the front of XX1 so special?
  18. #418
    wrench
    Reputation: mattomoto's Avatar
    Quote Originally Posted by vapezilla View Post
    I have a fair amount of time on a chain (since mid August) and it is doing just great. I am pretty good about cleaning it quite often but it has seen some abuse too. Since there were not many of these chains in early going, this particular one went through World Cup finals, training, Olympics, more training and World Champs then on to my bike for some more abuse and Iceman. Continues on today
    Sram does say it is their strongest chain they have ever manufactured. Time will tell. Building up my new Trek Superfly 100 SL this week with a new group. Can't wait to get out on it even if it is in the snow!!!!
  19. #419
    Reputation: limba's Avatar
    Let us know what you think of the new frame too.
  20. #420
    wrench
    Quote Originally Posted by limba View Post
    Sure will. If it is half as fantastic as the SL hardtail I have been riding, I will be on cloud 9!
  21. #421
    Oct 2011
    I've been considering this drivetrain for the past few days, and I'd like to thank all of you for this enlightening thread !
    However, there is one question whose answer I can't find : could I go from a 28t chainring to a 32t without changing the chain ? Assuming that my primary chainring would be a 30t.
  22. #422
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    Quote Originally Posted by Noosphere View Post
    Yes Just. I have been told that it can cover 4 teeth difference. I haven't fitted my 28 yet but use the 30 & 32 with same chain no problems .
    In the grand skeem of things even if you couldn't what an extra chain.
    Raising money, my friend broke his neck Mtbing, Please Share link. http://givealittle.co.nz/cause/elliottkeys/donations
  23. #423
    I had the same question. I'd want a 36 or 38 tooth ring. So I'd put one of those on the crank, fit the chain and then keep the 32 around in case I go somewhere hilly or buy a 29er.
    These chains are supposed to last so if you did switch rings you could keep the old ring/chain combo together in case you switch back.
  24. #424
    Oct 2011
    Quote Originally Posted by muzzanic View Post
    Very true, not having to switch chains would just be less effort
    Thanks for the info.
  25. #425
    Carbon & Ti rule
    For that matter having 1 bike with 28 tooth & 1 with 32 tooth rings would be even less effort
    Thats if you don't count the extra effort it would take to make the money to pay for it.
