Results 1 to 11 of 11
    Jan 2016
    SRAM 11 speeds climbing
    I bought a 29in hardtail, 20 pounds(used) that i like, it has a SRAM 11 speeds 32 teeth with 10/42, for easier climbs with a packsack or after 3 hrs of riding may i get a 28 teeth, i have 4 bolts 96mm BCD, may i get a cassette with 46 teeth or should i make the move to a 12 speeds, hopefully turning a bike i like into one i really like, thanks, a new fat/mountain biker
    ps. please give me a dollars idea for your suggestion
    Jul 2014
    I've seen 28T with 64bcd (Northshore Billet), not sure about 67bcd, what crank is that?
    Reputation: brent701's Avatar
    Sep 2012
    It all depends on your area.
    I can get away with my 34T chainring and SRAMs 11-42 cassette,
    But some races, Like Whiskey that 50T or a 2x would have been nice due to my fitness level.
    But ALL my SRAM drivetrain is going away and being replaced with Shimano which offers a 11-46 cassette
    Too Many .
    Jan 2016
    I appologize i made a mistake, it is a sram xo1 96mm i did not mesured properly, sofar a local bike shop can order me a 30 teeth for 28 dollars it might be what i will choose to go for
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    Quote Originally Posted by 33red View Post
    try that out before going 12 speed
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
    Reputation: Lone Rager's Avatar
    Dec 2013
    Might that be an x-sync crank with removable spider? If so you can get a smaller direct mount ring.
    Do the math.
    Aug 2014
    Need to figure out what top speed you need.... Most trail mountain biking is less than 25mph and also depends on fitness level. I would do the 28, would give you plenty of granny for climbs but lose some flat out speed. Look at a gear calculator to see exactly what you gain and lose.
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    Short-Change-Hero
    Reputation: gregnash's Avatar
    SunRace is actually supposed to be releasing an 11-50 11spd cassette shortly here, may be worthwhile.
    Jan 2016
    Quote Originally Posted by gregnash View Post
    Thank you for the info, i will start with the chainring change use my cassette and chain and have that option in some months when they need to be changed if my derailleur will permit it
    Aug 2014
    The least expensive way is the chainring and they are easy to interchange if needed. No need to replace working kit, better to replace when broke or at the end of their service life. I'm using a Absolute Black oval 26 w/ 11-36 shimano and getting to point of replacing with a 30T.
    Jul 2017
    I just made the switch from my XO1 32 t to the North Shore 28 and what a nice difference for the steep stuff. They are on Ebay now for $37 shipped and worth every penny.
  1. Replies: 11
    Last Post: 01-11-2017, 08:15 PM
  2. Are 10 speeds cassette compatible with old 9 speeds freewheel/hub?
    By Ziguy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-22-2015, 07:12 PM
  3. 11 speeds cassette minus one cog on 10 speeds freehub
    By igonzo128 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-16-2014, 02:46 PM
  4. Sram XX1 with 9 speeds chain..Is it workable ?
    By edle in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-27-2013, 06:42 PM
