Results 1 to 5 of 5
Thread: spokes breaking
    Dec 2012
    spokes breaking
    had a spoke break on a ride the other day , took my 12 epic into the shop to get it replaced. next day they call stating that they replaced the spoke but when they try to true the wheel the other spokes are breaking. so they are going to replace all the nipples to stop it from happening. the shop stated the nipples are too dry. any advice on this? i have only been riding for a little over a year and dont know much about spokes and wheels. my bike was bought new about march. should i be lubing spokes and nipples?
    May 2005
    No, you shouldn't be "lubing spokes and nipples". Usually when you build a wheel you use either a special compound (spoke prep), linseed oil, or other lubricant on the threaded end of the spoke. But even if you build a wheel "dry" it shouldn't cause the spokes to break unless there is corrosion and the nipple and spoke get stuck. (Most stock wheels are built by machines and not by hand, but I don't know if they use anything type of spoke prep compound or lubricant).
    I'm a little suspicious of your shop. There could be a problem with your wheel, but it sure sounds like an inept, unexperienced mechanic to me.
    Reputation: shiggy's Avatar
    Dec 1998
    spokes breaking
    Quote Originally Posted by mike91 View Post
    If the spokes are breaking replacing the nipples will fix nothing.
    "Dry" nipples can be lubed without replacing anything, and is needed only if/when the wheel is trued.
    If this was my wheel I would completely relace the wheel with new spokes and nipples, and not let this LBS touch it.
    mtbtires.com
    50% Acetone and 50% ATF makes the best corrosion breaking penetrant. Your should put it ina glass jar and shake it up before putting a little on each nip and probably waiting overnight Brass nipples would be better.
    Rusty bolts? Make your own super rust penetrant! Grassroots Motorsports Magazine
    Plays with tools
    Reputation: customfab's Avatar
    Are the heads shearing off the nipples? Common result of spokes being to short. Swapping from aluminum to brass is a half baked solution but normally works. Still better to rebuild the wheel with spokes a mm or two longer.
  1. Roval control trail SL, breaking spokes
    By madhead in forum 29er Components
    Last Post: 09-12-2012, 09:33 AM
  2. Why do my spokes keep breaking?
    By 86 slo-vo in forum Wheels and Tires
    Last Post: 10-15-2011, 07:31 PM
  3. I keep breaking spokes.....re-lace the wheel?
    By VTSession in forum Wheels and Tires
    Last Post: 10-07-2011, 09:19 PM
  4. Problem with spokes & nipples breaking
    By lginzkey in forum Specialized
    Last Post: 07-11-2011, 07:08 AM
  5. Fat Sheba Spokes Breaking?
    By bdundee in forum Fat bikes
    Last Post: 06-22-2011, 04:34 PM
