Results 1 to 2 of 2
    Oct 2017
    Specialized 2014 Epic Bottom Bracket creaking
    So I have looked at all of the threads about bottom brackets and I am having a real hard time understanding why Specialized can make a high end product and shove plastic bottom bracket in it and call it good. That being said. Who's got the answer for a bottom bracket that will not creak. I have ran the Wheels manufacturing treaded bottom bracket, their aluminum press fit, ad the SRAM PF-30. The only one that seems to work is the SRAM one which only lasts for about 6 months. You would think the more secure you could make the bottom bracket the less chance of it creaking. Des anyone have a good fix for this? I have both a aluminum world cup and a carbon one. They both suffer from the same thing.
    Oct 2011
    Had the same issue with a 2014 S-Works Epic. Specialized recommended using 3M 420 epoxy. Worked like a champ for me and was still able to remove it without issue.
  1. Using Bottom Bracket Wrench vs. Bottom Bracket Socket
    By BobaX in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-21-2016, 10:36 PM
  2. Specialized Fuse bottom bracket creaking noise?
    By MTB9488 in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 09-03-2015, 08:02 PM
  3. Specialized fatboy bottom bracket creaking noise
    By MTB9488 in forum Fat bikes
    Last Post: 08-26-2015, 09:53 AM
  4. Replacing a Shimano MTB HT II bottom bracket with a Shimano Road HT II bottom bracket
    By AndrwSwitch in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2015, 11:58 AM
  5. Giant Talon 2 29er crank/bottom bracket creaking noise
    By prince_ruben in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-08-2011, 10:58 AM
