Results 1 to 7 of 7
    Dec 2013
    Sontour XCM LO 29er 80mm
    makes some sense to you, make these holes in the fork to improve performance? (2mm drill holes ),
    ballbuster
    Reputation: pimpbot's Avatar
    Wait... you want to drill some holes in your fork? Really? Sounds like a cosmically bad idea to me.
    What is the issue you are trying to solve?
    Cannondale does that sort of thing on the older Lefty forks, to let air in and out of the sealed boot. They can get away with this by surrounding the air ports with a filter system, so the fork doesn't suck in water and dirt whenever the fork compresses.
    The only way to improve the performance of a Suntour fork is to replace it with a Rockshox Reba.
    Dec 2013
    i read an article in another forum, they say this could improve the performance of the suspension, make it softher on rebound etc etc....
    Nov 2012
    Quote Originally Posted by pimpbot View Post
    Yep that's what I did but only after careful consideration of the 2mm drill hole option.
    Dec 2013
    any comments about ??
    Reputation: TheDocTx's Avatar
    Apr 2013
    Go for it.
    Dec 2013
    I made the holes, two on each fork leg with a 2mm drill ..... I went to the track and I notice a big difference ..... there are parts of the track where felt stiff fork ..... Soft felt now .... greatly improves.Sontour XCM LO 29er 80mm-img-20140124-wa002.jpg
  1. 80mm 29er fork as 650b?
    By zarr in forum 27.5
    Last Post: 03-24-2013, 10:51 AM
  2. Sontour to have 7 650b forks!
    By ljsmith in forum 27.5
    Last Post: 10-02-2012, 06:09 PM
  3. Replies: 2
    Last Post: 05-06-2011, 12:51 PM
  4. Replies: 0
    Last Post: 05-04-2011, 06:37 AM
  5. Can I make a Fox 29er 100mm to a 80mm?
    By Killrop in forum 29er Bikes
    Last Post: 03-16-2011, 02:32 PM
