Results 1 to 3 of 3
    Reputation: andrewkissam's Avatar
    Jan 2014
    Slightly broken derailleur cable. What do I do?
    The other day I was doing a routine tune up on my xc hardtail and I noticed one of the wire strands of the front derailleur cable snapped. Not the whole cable, just one strand right where the derailleur clamps on to the cable. Should I be concerned about this causing any problems? The derailleur still shifts fine though.
    Thanks guys
    Sep 2012
    Nothing to worry about and pretty common. It obviously won't cause any binding since it isn't entering any housing and the cable is still plenty strong.
    REI has Novara/Jagwire lined housing and slick stainless cable. A kit is $19.
    When you change it think of going full length. Less ferrels and very smooth shifting. This is likely much better quality then what's on most bikes.
    This upgrade makes more of an improvement for the money spent than any other one I can think of.
    Novara Shift Cable Kit at REI.com
    Cut with the correct cable cutter after supergluing the area. Add a drop to the cut end. Sand to a rounded tip. Then thread through the lined housing to keep it intact.
  1. Broken dropper cable
    By Bigb2000 in forum Specialized
    Last Post: 11-15-2013, 05:14 PM
  2. ASR 5C broken cable guide mount.
    By matt462 in forum Yeti
    Last Post: 11-30-2012, 12:07 AM
  3. QBP cable housing $1/ft; Sram Derailleur cable $2/set; free ship over $30
    By bob13bob in forum Where are the Best Deals?
    Last Post: 03-29-2012, 06:51 AM
  4. broken rivet nut on downtube cable routing
    By blantonator in forum Yeti
    Last Post: 09-11-2011, 04:09 PM
  5. Is my derailleur broken?
    By nikojan in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-11-2011, 07:04 PM
