Results 1 to 2 of 2
    Mar 2013
    Shimano XTR m988 brake lever + Saint m820 brake calliper
    I am currently using shimano XTR M988 brake, however i've been wanting to upgrade the calliper to Saint M820 for more power. If I use the Saint M820 brake calliper, is it possible to use the hydraulic brake cable of Shimano XTR?
    ballbuster
    Reputation: pimpbot's Avatar
    All of Shimano's brakes are mix and match compatible, apart from the hose connectors. Just get the right ends for the hoses (or the right hose with pre-installed ends), and you should be fine.
    I'm surprised you want more power. Are you trying to stop a DH bike in DH conditions? I gotta say, I'm 215 pounds and ride steep stuff all the time. I feel even with 160mm rotors and XT or XTR calipers, I have plenty of one finger stopping power. Occasionally on really long steep descents, I can overheat my brakes, but not very often.
    Are you sure you don't have contaminated pads? I would try sintered/semi metallic or kevlar pads if you haven't already. See if that helps.
  1. New Saint M820 brake set-up. Help needed.
    By PeytonP in forum Downhill - Freeride
    Last Post: 01-06-2014, 02:35 PM
  2. Replies: 3
    Last Post: 11-25-2013, 03:37 AM
  3. Replies: 3
    Last Post: 06-03-2013, 07:05 PM
  4. Brake suggestions? Shimano XT/XTR-m988/Saint m810
    By mtbheezy in forum Brake Time
    Last Post: 09-18-2012, 06:18 PM
  5. new m820 saint, brake pads.
    By delirian in forum Downhill - Freeride
    Last Post: 08-31-2012, 03:58 PM
