    Jan 2013
    Shimano XT caliper & 170mm Avid rotor
    1) I'm running Avid Elixir 5 with 170mm rotor on Giant Anthem 29er 2013 and going to buy new Shimano XT BR-M785 brakes. Since they do not come with rotors I want to use the original Avids with the Shim brakes. What adapter/spacer should I use with this combination? Can I use the original CPS adapter? I have that 170 mm in the front.
    2) Rear rotor is 160 mm Avid. Is there any adapter needed for the Shimano caliper and 160 mm Avid rotor or can I mount it directly on the PM frame? Thanks for your help!
    Feb 2010
    I just got the same bike and put on the xt brakes as well. I was able to use the spacers that came with the Elixirs and it matches up and has worked for me. The rear should just mount to the frame.
    Jan 2013
    Nice :-) What spacer did you use and how did you mount the caliper?
    Feb 2010
    My bike came with a spacer that was about 5mm so I put that between the caliper and the post mount on the fork. I believe I used the avid bolts since they were a little longer. I haven't had a problem so far and the pads are lined up on the rotor perfectly..
  1. Avid HS-1 Rotor with BB7 Caliper?
    By magnato1 in forum Brake Time
    Last Post: 05-01-2013, 09:13 AM
  2. Shimano caliper with 185mm Avid G2?
    By jpedders in forum Brake Time
    Last Post: 02-08-2013, 11:47 AM
  3. Shimano XT M775 caliper and Magura rotor
    By Ptor in forum Brake Time
    Last Post: 11-08-2012, 05:53 PM
  4. Shimano Rotor Compatibility w/ Formula Caliper?
    By half_man_half_scab in forum Brake Time
    Last Post: 11-27-2011, 10:12 PM
  5. Replies: 6
    Last Post: 05-05-2011, 06:40 AM
