Page 2 of 2 FirstFirst 12
Results 51 to 78 of 78
  1. #51
    Feb 2012
    Ti Spindles...so I got my sweeetness in! excited to change em...BUT, how do you change spindles...don't wanna screw my pedals up...there is a nut that looks like it should be removed, input would be appreciated!
  2. #52
    XTR for $120 on chain reaction
    I've had them on my TB for a yr now, NO problems. I weigh 170
  3. #53
    ballbuster
    Reputation: pimpbot's Avatar
    I dunno... I'm not sure ti spindles are all that. You blow $50 to shed what... 15 grams? Seems like an expensive way to save weight.
    Plus, the ebay cadence magnet won't stick to it.
    Plus, I've seen the posts where folks broke off the threaded tips of these things.
  4. #54
    Quote Originally Posted by pimpbot View Post
    It is not a lot of weight that you save, but the price of 540's with Ti spindles is about $50-$75 less than XTR's alone, and the weight is nearly the same. So IMO it is a better option, and worth the $50 upgrade.
    XT's with Ti, cost about the same as XTR, and they should weigh slightly less than the XTR's. Still a great option, but perhaps not as much bang for the buck.
  5. #55
    One Gear
    Reputation: .40AET's Avatar
    Spend the extra money on lighter tires.
  6. #56
    Quote Originally Posted by DirtyHank View Post
    Pray tell me where does one get Titanium Spindles...TBay?
    All kidding aside...I'm Serious,
    Thanks,
    Hank
    I am using these; http://www.ebay.ca/itm/170889392756?...#ht_603wt_1163
    XT spindles are heavier than XTR as well
  7. #57
    Feb 2012
    There IS an American company making them (Ti Spindles). How do you get the current spindles out?
  8. #58
    ballbuster
    Quote Originally Posted by everything motorcycl View Post
    You can probably find an exploded view on the interwebs somewhere, but basically the spindle/bearing assembly unscrews from the pedal body. You put the body in a vise (don't crush it, just to hold it still) and you take a wrench to the hex thingy where the spindle goes in. That hex thing contains the bearing races, cups, cones, spindle and everything. Once you take that out, you can disassemble the cup and cone bearings and move the whole thing over to the Ti spindle.
    *edit*
    Oh, I forgot. Some pedals use a big hex thing to unscrew the spindles, some use a funky splined thing that takes this special tool:
  9. #59
    Feb 2012
    Thanks Pimbot, that 'hex thingy' is what I figured...but forgot about those bearing...will let my lbs change em.
    I really wanna put my new xt's in NOW, but w a race in the a.m., w my luck they will fail or something will go wrong. Will put them in after race and hope to have .01 seconds off my lap times due to unsprung weight savings (-:
  10. #60
    @trailgrinder
    Reputation: Live2rideUtah's Avatar
    I have been happy with my egg beaters, I have ridden them since 02 and have had no problems with quality or entrance or exits from them. I may venture into the xt's when my current pair decides to give up the ghost but for me the eggbeaters have been pretty bullet proof. I do like that they are light but that has never been a reason for me to choose one vs another.
  11. #61
    Feb 2012
    Agreed Live. I'm assuming one should pick and use what they WANT. Unless you are a National competitor, can't even imagine that 20-50 grams makes a difference.
  12. #62
    @trailgrinder
    I know weight and rotational weight is a big deal but I always figure I could loose 2 pounds off my ass first. My biggest thing is durability, if I can keep the weight down and not have to worry about seizing a pedal up in the back country al, is good. So it sounds as the xt's are pretty close to the xtr's and a little lighter on the pocket. For some reason I get all warm and funny when I see the xtr's and fall into the marketing and pay extra myself. One thing I can say is cool that crank brothers did this year was the buy back program, send in your old eggbeaters regardless of shape and get a new set of 2's for $60.00. Pretty good deal especially if you had an old set sitting in a box like I did.
    THey are on Evil Bay. Shame is, I don't know what comes with XTR or XT's as they don't list it on their website. That said, 540s plus spindles look like one great set up. I elected for the XTs, will keep you posted.
    Anyone know if the XT's come w ti?
  13. #63
    ballbuster
    Yeah, good move
    I personally don't change anything important two weeks before a race, especially drivetrain. I want at least two or three good rides on anything new before I trust that it's solid enough to race on.
  14. #64
    Feb 2012
    Live2, great success, so why switch? Just to try?
    Yeah, had my first 2 lap race today...kept old peds on...I have to learn to control my starts...I keep gassing after about 15 min...then after about another 15 min, I get my legs back.
    It is a motorcycle 'thing'. I see racers, I like to pass (-: On a motorcycle, you pass, your gone
  15. #65
    Mar 2011
    Xt vs XTR vs
    I have always been an XTR fan but switched to CB Candys. The candys have a more consistant release when riding in fine dirt aka Moab red sand. Than the XTRs. The orig. Cands had weak seals and needed rebuilds more often, the new CBs are much better. You need to replace the cleats if you ride alot, about 1 a year for me.
  16. #66
    @trailgrinder
    Yeah I would only switch it up for fun, of course keeping the egg beaters around but I will never know if I'm missing ou on something ifi don't give it a whirl.
  17. #67
    For anyone interested I saved 50g by swapping my XT spindles to Ti for $50 - and XTR and XT spindles are interchangeable.
    Brought them down to 289g
  18. #68
    .44
    Reputation: stremf's Avatar
    Dec 2012
    I've got a set of XT pedals that are 15 years old still going strong. There is a big chunk missing out of one of the cages from falling off the car going 80mph. Still butter smooth. Service is super easy and takes literally 5 min. I've got a bunch of 540's and another pair of XTR's. No issues with any of them through all these years of abuse.
    I'd like to someday try out another set of pedals, but at this point, I'm not going to try and fix something that's not broken.
  19. #69
    Feb 2012
    I hear ya stremf...
    For all...just installed, really like, but very honest...I mtb 3 x a week for last 8 months...so fairly new to sport but have athletic background.
    I couldn't see ANY benefit from my New XT's vs my 520s!!! Maybe 520s a bit better broken in...not sure if there is such thing as 'break in' on them. BUT: there is DEF less float on XTs. Very little in comparison to my 520s...I prefer a bit of float...so hoping that maybe when spindle works in, will have a touch.
  20. #70
    Jan 2005
    I've had egg beaters and just didn't like the feel of the pedal under my shoe. Used Time Atacs for about 5-6 years when Shimano's weren't known for shedding mud as well. Originally switched to XTR's because they were cheaper and lighter than the high end times. Had 2 sets of those and the only reason I stopped using the second pair was my fault because I let them get seized in a crank arm on a winter bike and cracked the threads trying to remove them. Raced everything from XC to 4X on them. No problems. The reason I have XT pedals is I was about 2 days out from a race and needed to buy pedals to replace the XTR's I'd messed up and XT's where the only pedals in stock. I don't notice a real difference between the 2 pedals. I think it's like a 30 gram weight difference. You can see the quality difference between the 540's and 520's though. If you can get XTR's for like $150 though do it.
  21. #71
    May contain nuts
    Reputation: Haggis's Avatar
    After riding Time XS for years, I'm now on XT Trail.
    The good: more shoe support means less roll and flex, especially when using softer-soled shoes, but even with hard XC shoes it's noticeable.
    The not-so-good: less heel float before unclip than Time, which makes for entertaining no-footers when deploying a bit of jump-style . (Currently trying to teach myself flats to learn proper foot/pedal/air technique)
  22. #72
    Nov 2012
    i went through this debate not long ago, I ultimately ended up with the shimano m540's.
  23. #73
    Nov 2012
    nashbar or pricepoint usually have good prices on them. ( Edit: )
  24. #74
    Jan 2005
    Quote Originally Posted by Haggis View Post
    I think every one should spend some time on flats. I think it adds a little extra to peoples skill sets. Dirt Rag had an article on riding flats in the summer.
  25. #75
    The best value for money pedal I ever used was/is the Shimano M540. The "problem" with these is that they last forever. You can only "upgrade" to slightly lighter. Not better.
  26. #76
    Always Learning
    Reputation: BruceBrown's Avatar
    I hear ya stremf...
    Hope they work out for you and "loosen up a bit" over time. Nothing wrong with Shimano pedals over the long haul. They just work. I've got the 520's on my Karate Monkey SS. Not as much float as my Xpedo pedals, but c'est la vie. I've got an equivalent pair of old Shimano clipless pedals I bought in 2002 that are still going strong (they are on my exercise bike in the basement). 10 years of non-stop functioning - hard to beat!
    The first reply to your original post (made by Dan_GSR) was - IMO - the golden ticket pedal suggestion for you in this entire thread. Xpedo. I've been running them for years with zero problems on multiple bikes. Love the 6 degree float as well. The Ti/Ti Xpedo pedals (M-Force 8) weigh a mere 215g and have been perfect. I've got 3 pairs of them, and 1 pair of the chromoly I bought back in 2005 and is still going strong. The chromoly model I bought is the equivalent of today's M-Force-3's that weigh around 312g. Although a more unknown pedal brand compared to Eggs and Shimano - these Xpedo pedals just work like a charm and are a great product.
    I went to the M-Force 8 (Ti/Ti) pedal on my JET 9 which I built out a bit weight weenie like a couple of years ago. I had the fancy Eggbeater light pedals on my new JET that had a cage snap and break in the middle of a race. I didn't even hit anything!!! Crank Brothers fixed them without much hassle, but after I got them back from CB service they are still sitting in the box on my parts table. I don't want to ride with a product that can just "break" while riding along. So I went to the M-Force 8's and haven't looked back.
    Nice review here.
    Too late for this time around, but next time around Xpedo is absolutely worth a serious look. Best pedals I've owned when you combine weight, function, price, and performance. If you shop around, it's not hard to find the M-Force 8 (Ti/Ti) pedal for $180 - $205. They remain my favorite pedal.
  27. #77
    Are the Xpedo hard to clip into? I bought a set of light weight SPD Ritchey V5 pedals and they were horrible to clip into. The 'square' design made it easy to think you were clipping in but your cleat was actually on the end of the pedal vs the flat since they were the same length.
    If that isn't a problem I definitely want to try the Xpedos
  28. #78
    Always Learning
    Quote Originally Posted by broadwayline View Post
    They are easier than the Shimano pedals to clip into and the more open cages allow for much easier clipping into when you have mud, snow or whatever on the bottom of your shoe around the clips. Like I said - they are a great product and the review I linked above pretty much nailed it. They are a "surprise" in a good way.
    Just don't have the huge brand recognition that Shimano and Crank Brothers does. It's fun to find a "surprise" product like a Syntace stem, an IRD FireXC Pro, an Xpedo pair of pedals, or a KMC chain etc.... that might be a bit more off the beaten path.
    BB
