Results 1 to 15 of 15
    Mar 2013
    Shimano m988 lever not compatible with I-spec
    I bought the shimano m988 lever left and right. The left lever is fully compatible with my xtr m980 shifter I-spec, while the right lever shown above is not compatible with I-spec.
    I checked shimano website, both left and right must be fully compatible with I-spec. Is this a manufacturing error?
    Did you buy it off one off those no name cheap Ebay sellers where the chance of it being a copy are pretty high?
    OG Ripley v2
    Carver 420 TI
    bike tester
    Reputation: syl3's Avatar
    lol m988 lever copy that would be one hell of a fake to attempt.
    more likely you got some OEM part...?
    Quote Originally Posted by syl3 View Post
    I've seen a lot more complicated fakes than a Shimano brake lever.
    OG Ripley v2
    Carver 420 TI
    Mar 2013
    Quote Originally Posted by TwoTone View Post
    I bought it at chain reaction cycles. I emailed them about this I am still waiting for their. Reply. The lever work perfect but I cannot install my shifter.
    Bandit 29 FTW!!!
    Reputation: In-Yo-Grill's Avatar
    I believe CRC sells a lot of OEM parts. Sometimes they are a little vague on their description.
    Let's make like a Bike and get the Huck outta here...
    Mar 2013
    I've been searching in google if there is difference between oem and non-oem m988. Both states are fully compatible with I-spec. In Crc website they described that this is compatible with I-spec as well. It's just weird both lever arrive and the left lever is compatible with I-spec while the right it isn't... This annoying.... If i return this to tome I need to wait 6 weeks before I could get the new one. So meaning 6 weeks without riding my mountain bike... I won't able to do that because 3 to 4 time a week I ride my bike.
    Seems odd. My stock TBc levers which you'd think are OEM if Shimano has an OEM version are ISpec compatible.
    OG Ripley v2
    Carver 420 TI
    Reputation: madskatingcow's Avatar
    The lever shown above is the new I-spec type B, for 2014. Not compatible with the earlier version.
    I just installed a set of 2014 XT's BR-M785 I-spec type B - looks exactly the same.
    bike tester
    Quote Originally Posted by madskatingcow View Post
    Do they offer any more or less adjustment than the original type?
    OG Ripley v2
    Carver 420 TI
    The shifter is still in a fixed position on the brake lever clamp. You can not rotate it to adjust it to your comfort. Standard was pretty good for me though
    Mar 2013
    Can you please post a photo of your lever.
    I got the xtr m980 shifter 2012. It should be compatible with I-spec even with the new ones?
    Quote Originally Posted by rave81 View Post
    He is trying to tell you no, it's not backwards compatible.
    Shimano I-Spec B « Singletrack Forum
    OG Ripley v2
    Carver 420 TI
    The image in the link above shows all :
    These combinations will work :
    - Old levers with old shifters
    - Old levers with new shifters
    - New levers with new shifters
    This combination won't work :
    - New levers with old shifters
    As the image shows, with the new type B brakes there are two type of 'nuts' included for fitting the b-type shifters.
  1. Shimano Xtr m985 vs m988 differences?
    By gsxrawd in forum Brake Time
    Last Post: 09-11-2013, 09:28 PM
  2. Replies: 7
    Last Post: 03-20-2013, 06:47 AM
  3. Replies: 2
    Last Post: 01-09-2013, 03:39 PM
  4. Shimano M775 caliper with M988 lever
    By gnarly in forum Brake Time
    Last Post: 12-02-2012, 09:17 AM
  5. Shimano XTR M988 problems
    By hisbabyf in forum Shimano
    Last Post: 08-02-2012, 08:09 PM
Members who have read this thread: 4
