Results 1 to 3 of 3
    Jul 2014
    Shimano HG-50 10 on an 8 speed.
    I want to put the Shimano HG-50 10 11-36t minus 2 sprockets on my bike. If I use 8 Speed cassette spacers will this work. The sprockets would be as follows
    11, 13, 15, 19, 24, 28, 32, 36
    another options would be to take a 23t and 26t sprocket off good condition hg41 cassette I have giving me
    11, 13, 15, 19, 23 26, 32, 36
    Would this work in theory and practice.
    Thanks Alex ... I'm new to this.
    Fat-tired Roadie
    Nov 2007
    It would fit on your wheel. It might not shift very well.
    What shifter are you using?
    Check out sheldonbrown.com for a ton of technical information, including stuff on cassette spacing and cog widths. I think the thing that drives whether this will work okay or not is what your center-to-center spacing ends up like.
    Will probably work but shifting may not be optimal - ramps won't line up.
    What about taking an 8 speed cassette, add the 36 cog and remove the smallest cog? That way all but the 36 would have the correct ramps etc. You might need a different lock ring for a 13. Your LBS might have an old 36 cassette and lock ring you could try - I would think the wear on a used 36 wouldn't be bad, good enough to experiment on.
  1. 9 speed/10 speed, Shimano/SRAM, Road/Mountain Compatibility Issues
    By Hundun in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-10-2014, 03:17 PM
  2. Replies: 8
    Last Post: 08-22-2013, 05:01 AM
  3. Can I use Sram 9 speed quick link gold with shimano 9 speed chain
    By crclawn in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-13-2012, 05:06 AM
  4. Shimano Press Fit 10 speed crank and 9 speed external cup compatibility question
    By wildh in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-20-2011, 11:45 AM
  5. Shimano XTR M980 Shadow 10 Speed Rear Mech and 9-speed system...
    By xr_mtb in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-24-2011, 07:08 PM
