Results 1 to 8 of 8
    VENI VEDI BIKI
    Reputation: skankingbiker's Avatar
    School me on tapered headtubes
    It seems most new 20er frames all have tapered headtubes. I have a standard 1 1/8 fork and headset. Is there any type of converter I can buy for the wider lower to still run my existing fork, or am I looking at having to upgrade to a new fork?
    Veni Vidi Biki
    I came, I saw, I biked.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by skankingbiker View Post
    Most of the headsets offer a fork crown for straight steer tube forks.
    mtbtires.com
    Reputation: Ronnie's Avatar
    You do not need to get a new fork. There are two options you have. Headset manufacturers make a bottom cup and bearing that fits a straight 1⅛" steerer tube into a tapered 1" head tube. Alternately you can get a 1" crown race to fit into a 1" bottom headset cup with a 1⅛" steerer. I used this setup for a while. I have a cane creek 110 headset and knew that I would get a tapered fork. This is the crown race from Cane Creek but other manufacturers have them too:
    The trouble with having an open mind is that people will insist on trying to put things in it.
    VENI VEDI BIKI
    Ok, I am assuming I would need to get a new lower cup & bearing as well? (i.e. I couldnt just use a 1 1/8 headset with the bigger race?)
    Veni Vidi Biki
    The headset cup has to fit into the bottom of the head tube.
    Reputation: 4nbstd's Avatar
    Ya, from what I understand, you have to buy the whole new headset.
    Ghisallo Wheels
    I'm really good looking.
    Dec 1998
    Quote Originally Posted by 4nbstd View Post
    New frame = new headset. No big deal.
    mtbtires.com
    VENI VEDI BIKI
    Thanks for the replies.
    Quote Originally Posted by shiggy View Post
    Veni Vidi Biki
  1. School Me On Headtubes
    By CharleyGnarlyP290 in forum Frame Building
    Last Post: 02-24-2012, 11:36 AM
  2. Tapered headtubes?
    By steel-s-real in forum Pivot Cycles
    Last Post: 07-20-2011, 04:11 PM
  3. Tapered Headtubes and Steerer tube ?
    By Evil4bc in forum Frame Building
    Last Post: 07-10-2011, 01:11 AM
  4. Tapered headtubes with 1 1/8 forks
    By phoeneous in forum Shocks and Suspension
    Last Post: 06-22-2011, 07:56 PM
  5. FS Tapered headtubes
    By 18bikes in forum Frame Building
    Last Post: 02-18-2011, 02:48 AM
