Results 1 to 5 of 5
    29er for the Soul
    Reputation: teachndad's Avatar
    Santa Cruz Superlight 29 - What type of front deraileur?
    Hi,
    I am going to build up a 2013 Santa Cruz Superlight 29. Can anyone tell me the type of front Deraileur that goes on it? I need upswing or downswing and any other information about it.
    Also, does it have a frame mount or clamp mount?
    So Cal Rod
    A 34.9 top swing/ top pull. Anything but saint should do the job.
    The Santa Cruz site has a FAQ page for each of their bikes.
    Santa Cruz Bicycles SUPERLIGHT29
    Select the Superlight 29, then go to Support tab on left then select FAQ
    Nov 2008
    Haven't checked the Santa cruz site, but the post above sounds about right. Just make sure you know If your gonna run a 2x10 or 3x10 crank. You'll need the match the front der with the crank. You probably already know this, but just FYI
    29er for the Soul
    Both responses have been very helpful.
    And to drs4400sm response, no, I hadn't considered that. I am glad you mentioned it. I am still debating which way to go with the two or the three or even back to 9 gears. I like dropping the outer chainring for a bash guard as on my current rig.
    cheers
    So Cal Rod
    Dec 2014
    Hi,
    I am on the same issue. I am planning to build a Santa Cruz SL 29, all the components from my HT 29er MTB, my concerns is about my SRAM XX 2x10 FD which is a high clamp top pull. Is anyone have any idea if the said FD will be no issue upon installing to the Santa Cruz SL 29ER?
    Thanks..
  1. Santa Cruz Superlight?
    By BenR in forum Colorado - Front Range
    Last Post: 05-27-2012, 10:01 AM
  2. Santa Cruz Superlight 29
    By enFuego in forum 27.5
    Last Post: 03-19-2012, 07:38 AM
  3. santa cruz superlight
    By bnelson in forum Endurance XC Racing
    Last Post: 03-15-2012, 07:37 PM
  4. Santa Cruz Superlight vs. KHS XC-604
    By M-80 Rider in forum Beginner's Corner
    Last Post: 06-13-2011, 08:49 PM
  5. BMC FS or Santa Cruz superlight
    By augustk in forum Bike and Frame discussion
    Last Post: 01-30-2011, 02:30 AM
