Results 1 to 13 of 13
    Rotor size on 2014 Superfly 9.8 SL?
    My current 2012 Superfly 100 AL elite came equipped with 180/160 rotors. Getting mixed info on 2014 SF . Anyone know what the rotors are spec'd at?
    It's on order comes in for test ride Saturday.
    Sent from my SCH-I535 using Tapatalk
    29ers Forever
    Reputation: CannondaleF9's Avatar
    Nov 2012
    They are 180/160mm rotors.
    Quote Originally Posted by CannondaleF9 View Post
    Hmm OK, I was coming back here to post because I just looked at a 9.7 and a 9.8 SL in a 17.5 and they were 160/160
    so not sure why the difference
    Crash Dummy In Training
    Reputation: PauLCa916's Avatar
    Jun 2013
    Quote Originally Posted by thomasshawn View Post
    Size of bike the Lg and XL have bigger rotors most likely that's my guess
    2015 Flyxii / ENVE /Chris King Carbon 29'er H.T.
    SRAM XX1
    2012 Stump Jumper Comp 29'er H.T. SRAM XX1
    1997 Rock Hopper / Rock Shox Recon Silver / 1 x 10 SRAM X9 XO Mix XT V Brake system
    Trek's Tech Site just shows 160 F&R for all sizes.
    29ers Forever
    Nov 2012
    In the pic on their site it shows a 180/160mm.
    ballbuster
    Reputation: pimpbot's Avatar
    Not sure why it matters much. Rotors are easily up/downsized.
    I'm 210 pounds and run 160/160 on most of my bikes with no overheating issues, and I ride a lot of steep hills.
    29ers Forever
    Nov 2012
    Quote Originally Posted by pimpbot View Post
    I am a little over 180lbs and I use a 203/180, but mostly for looks instead of performance.
    Dec 2010
    Just because the pic shows it, doesn't mean it's what you'll get. As PauLCa916 said, the L and XL bikes most likely have bigger rotors, but it is very likely that all sizes are spec'd with 160/160. OP just looked at a 17.5 with 160/160...
    I'm OP & just received the 21" 9.8 Superfly SL and it came spec'd with 160/160. Now these are the "ice tech" rotors that are supposed to dissipate heat better and thus not require 180 or 203 for adequate stopping. I've got about 50 miles on and thus far haven't noticed and stopping power issues (they stop just fine) haven't been on them enough to notice if they'll suffer fade from overheating but they are marketed specifically not to do that.
    Mar 2013
    It might depend on the frame size, I know some manufacturers change various parts based on frame size.
    FWIW, I have a 2013 Superfly 100 (XL) and it has 180/160
    Trail Ninja
    Reputation: Varaxis's Avatar
    Depends on bike weight too. Maybe the 9.8 SL is light enough to warrant the smaller rotor. I know the alloy models would likely feel better with a 180 up front due to the extra weight.
    Reputation: DethWshBkr's Avatar
    Dang. I have the 2014 Fuel EX8 29er with 180/180, and I will be upsizing to 203/203. My '08 Fuel EX9 with Juicy 7's has 180/180, and stops beautifully.
    My Fuel EX8 29er is under-braked with those SLXs and the 180 rotors. I don't blame the brakes themselves, but the rotor size.
    I noticed on a steeper downhill (short) that I had "enough" brakes, but not mind blowing brakes. I wish I could run something larger than a 203, I would!
  1. 2013 Trek Superfly vs 2014 Superfly...
    By Bryan1113 in forum 29er Bikes
    Last Post: 04-12-2016, 01:20 AM
  2. Replies: 18
    Last Post: 04-21-2015, 10:38 AM
  3. 2014 X-Cal 8 or 2014 Superfly 5?
    By 80sforlife in forum Trek
    Last Post: 01-26-2014, 04:44 AM
  4. Rotor-Q on 2011 Trek superfly elite 100?
    By BMSrider in forum 29er Components
    Last Post: 10-04-2013, 11:23 PM
  5. 2014 superfly 100 ?
    By multitool in forum Trek
    Last Post: 08-27-2013, 08:52 PM
