Results 1 to 6 of 6
    Sep 2017
    Rockshox Pike from 120mm to 140mm?
    I have the Rockshox Pike RC29 that's currently at 120mm. I've read somewhere that you can change the air chamber to increase travel. Can you change any Pike fork from 120 to 140 up to 160mm?
    WillWorkForTrail
    Jun 2012
    I think you can go 120 - 140 or 140 - 160. But don't hold me to that. That was kind of like something I got from a conversation I half overheard. In theory all you need is the air spring to make it happen. I'm fortunate enough to have a really good suspension guy at my local shop, so if it was me, I'd go see him and at least have him check it out before I spent any real money on it. Do you have a good suspension guy/gal locally?
    Nov 2016
    The new Pike 29 fork only goes up to 140 mm.
    2018 Guerrilla Gravity Trail Pistol XXL
    2017 Stumpjumper Comp 29
    2016 Fuse Pro (29er)
    West Chester, PA
    Quote Originally Posted by Graveltattoo View Post
    Prior to the 2018 models there are two different uppers, 120-140 and 140-160. So a fork delivered as 120 can only go to 140. A 160 can only be reduced to 140.
    To change the travel within those ranges you just need to swap in the appropriate air shaft. It's not difficult. Sram has a video on YouTube that walks you through it.
    Jun 2014
    Air shafts on eBay for $25ish and beyond that you need snap ring pliers and suspension fluid. A few standard tools too, of course.
    120-140 adjustability range is correct. 120 all the way to 160, no.
    Sep 2017
    I called the Rockshox service center and they told me the Pike solo air can go from 120 to 160mm, just need to change the air shaft.
  1. 29+ Rockshox Pike 120mm RCT3 or 27.5+ Fox 34 Float 120mm
    By bpd131 in forum Shocks and Suspension
    Last Post: 04-29-2016, 11:05 AM
  2. Pike 29er 120mm now and 140mm later
    By manamana in forum Shocks and Suspension
    Last Post: 07-03-2015, 05:30 PM
  3. Niner RIP 9 - Pike Fork 120mm or 140mm?
    By Lucky5s in forum 29er Bikes
    Last Post: 07-02-2015, 08:07 AM
  4. Replies: 8
    Last Post: 05-06-2013, 05:37 PM
  5. Reba 140mm reduced to 120mm vs. Reba with 120mm stock
    By thekaiser78 in forum 29er Bikes
    Last Post: 06-30-2011, 04:15 AM
Members who have read this thread: 33
