    May 2013
    Rock Shox SID RCT3 29er Forks
    Guys,
    I'm a newby to the forum and have just upgraded bikes to a Niner Air9 29er. The problem I am having is that I need to remove the front wheel as the brakes (AVID Elixir3) are rubbing on the rotor. However the forks do not have "lawyer tabs" but rather a bolt through enclosed housing (see attached picture). I have undone the quick release clip but it doesn't allow the front wheel to be removed, can anyone advise on how you remove a wheel for this type of setup?
    Cheers in advance.
    Attached Thumbnails Attached Thumbnails Rock Shox SID RCT3 29er Forks-forks.jpg
    Formerly of Kent
    Reputation: Le Duke's Avatar
    You unscrew it, counter clockwise.
    Is this a serious question?
    Death from Below.
    Formerly of Kent
    Also, you don't need to remove the wheel to fix rotor rub. You need to adjust the brake pads, or calipers.
    However, based on the question you just asked, I'd suggest taking the bike to a qualified bicycle mechanic and having them do it for you.
    Death from Below.
    May 2013
    lol. Yeah righto, I can see the error of my way now, however in my defence part of the housing was broken to lock in the quick release clip to unscrew the bolt so it was not as obvious to me as it should have been.
  1. Rock Shox vs. Fox Forks for XC Rider (29er)?
    By Muffinhead in forum Beginner's Corner
    Last Post: 11-29-2014, 09:37 AM
  2. Replies: 51
    Last Post: 05-20-2013, 06:12 PM
  3. Rock Shox SID RCT3 29er performance and oil volumes
    By biking_dane in forum Shocks and Suspension
    Last Post: 06-25-2012, 11:35 AM
  4. Rock Shox SID w RCT3 on SS?
    By Raybum in forum Singlespeed
    Last Post: 05-22-2012, 01:05 PM
  5. Rock Shox SID RCT3
    By Sb.Reno in forum Shocks and Suspension
    Last Post: 04-19-2012, 02:08 AM
