Results 1 to 17 of 17
    Rigid fork install for RockHopper Comp 29er?
    Posted this over on the specialized forum, but didn't get any responses - any help would be greatly appreciated:
    I've recently acquired this bike, and I am very happy with most of it. I'm not particularly excited about the irritating investment of time that has to go into bleeding the hydros, if they really need annual bleeding, but I'm especially underwhelmed by the flexibility of the SR Suntour front fork (the front brake rubs whenever I'm leaning hard one way or the other, but is otherwise perfectly aligned). I am considering swapping it out for a rigid fork - I tend to spend more time on the tarmac/packed trails than off road these days, and should probably have opted for something without suspension (stupid hindsight!) - but I suspect that I might have to have the LBS do all the dirty work for me (despite the extravant cost of such an undertaking). I don't think I'm going to have much trouble finding a fork for a really low price, but just how involved is it to replace the fork? I know it's not just a matter of removing the stem and sliding out the old fork to replace it with the new one (that's what I'd like, though). It seems that I'll need a headset (or at least some replacement pieces from the current one) along with the new fork. Is this something that only a trained professional should undertake, or can a person with basic mechanical skills and a certain amount of intelligence (but no more) actually accomplish this task?
    Thanks in advance for any comments - even the funny ones!
    Riding rigid
    Swapping forks is easy. You'll have to knock out the lower headset race (usually pressed into the crown) and press it back on the new fork (you can use a 1.5 inch pvc pipe from the hardware store). Then the only other thing is trimming down your steerer tube (pipe cutter). Everything else is just bolt it back on.
    What could go wrong ...
    Reputation: Zoke2's Avatar
    Nov 2007
    +1 to what MTB Pharm said and make sure to measure the a2c on the fork you have to match it to the one you get to replace it
    I used to ride to Win ... Now I ride to Grin
    While my guitar gently weeps, my bike sits there mocking me
    Reputation: 4nbstd's Avatar
    It's definitely doable with a person who has basic mechanical skills, but I can see why it could be overwhelming when doing it for the first time.
    Look up videos on Youtube, there are some kids doing the job, so I can't imagine it will be too hard.
    For me though, fork install is one of the things that I would pay to get it done than doing it myself, mostly because the LBS does it for $35 and I don't want to deal with it.
    Quote Originally Posted by 4nbstd View Post
    Seriously? $35?!?! That's what my lbs charges to have the brakes adjusted. I'm talking vbrakes, too. I'll have to check around for these videos on YouTube. Thanks everyone!
    Quote Originally Posted by MTB Pharm View Post
    So how much of the new headset would I have to buy, if any? Are there parts I need and parts that I can just reuse? The star nut, for example, must not be the sort of thng one just yanks out of the old steerer tube. Right?
    Nov 2007
    Quote Originally Posted by dosland View Post
    Yes you will need a star nut for the new fork but all you need to do is remove the race from the old fork and put it on the new fork ... no need to change anything on the headset
    Reputation: Nubster's Avatar
    You might even score a free star nut from your LBS or at least cheap. Certainly they have some laying around from installing new headsets in frames that the forks didn't need a new star nut. I know I have several around here.
    Kona Big Unit SS
    Kona Private Jake SSCX
    DiamondBack Release 3
    <iframe width="420" height="315" src="http://www.youtube.com/embed/t1Op6XknHMU" frameborder="0" allowfullscreen></iframe>
    THanks, everyone, for these answers! Truly helpful stuff. I have a couple last questions before I jump off this cliff. First, what is my best material option (not really excited about carbon at this point, as the bike does spend a few hours every day in crowded bike racks) - from what I understand, I'm choosing between aluminum and steel. I do some single track riding, but spend far more time on the pavement/crushed limestone, so I'd just switch out the tires whenever I hit the trails. I'm 175lbs and 6ft, so I don't think my size/weight will have much affect on which material is most appropriate, but I'd like to have some opinions from people who have ridden both, or all three, I suppose. I rode an all steel hardrock (rigid) for 10 years, never had a problem until the derailleur hanger got destroyed in a nasty shifting disaster. That's about the extent of my experience with these mt bike gizmos!
    I haven't been on aluminum rigid fork before, but I've been on both steel and aluminum frames, and currently ride steel frame with rigid steel fork (2010 Kona Unit). Based on my experience with frame alone, I would go with steel fork.
    (I'm not even sure if they make aluminum rigid fork for 29er? I don't think I've seen one before).
    You will also need a 185mm I.S. disc brake adapter, $11. Your current fork is post mount, most rigid's are I.S. mount. You will also need a star nut $2-3.
    Avid CPS Mounting Bracket > Category | Jenson USA Online Bike Shop
    Tools you need: Bench vice and sharp hacksaw/ or pipe cutter, file, punch or big flat screw driver, hammer. Most shops charge $30-40 to install a fork.
    Bikeman Kona P2 29er Disc Fork
    same fork, with canti mounts also is on sale for $30.
    Riding rigid
    [QUOTE=thad;9473212]You will also need a 185mm I.S. disc brake adapter, $11. Your current fork is post mount, most rigid's are I.S. mount. You will also need a star nut $2-3.
    Good catch Thad. Yeah, most rigid forks have IS tabs, so you will probably need to pick up a new adapter.
    I vote steel fork too.
    There are a few around, exotic makes the ones I've seen, but cannondale and bontrager and maybe kona have all made them at some point.
    eXotic 29er Rigid Alu MTB Bike Fork Disc V Mounts | eBay
    CarbonCycles.CC :: Components :: Products :: Forks - MTB Alloy, 1.1/8 in Steerer :: eXotic Rigid Alu MTB Fork - Disc Only :: CC-F0945
    Couple sites (or sellers) that have them listed. Maybe no more interesting than a carbon fork, though?
    I guess I haven't bothered to look for them.
    Reputation: Cycloid's Avatar
    Apr 2016
    Fast-forward four years and I too have a 2013 Rockhopper that currently has super crappy Suntour XCM Lockout 100mm forks which need some work, but which, as others earlier in this thread agree, are not even worth working on.
    I have a Motobecane Night Train (w/o Bluto) arriving in a few days. I live on the northern Oregon coast, and intend to ride the NT mostly on well-maintained gravel logging roads, occasionally on the beach, and a bit on pavement, so I think I will do fine with a rigid configuration on the NT.
    So I was thinking about repurposing the Rockhopper into an in-town bike. I recently put some Big Apples on it, which are sweet, and figured that I might do well by putting rigid forks on the beast, thereby simplifying my life in this rainy, salty environment.
    I am a f**king noob (that is, a forking noob), so could I kindly solicit some input about some functional forks that would fit the Rockhopper? I don't need carbon. Weight is not an issue. Might AL be a good way to go, given that I'm in a wet, salty place, and given that the frame is AL? (I'm totally open to steel.)
    The last poster suggested eXotic (four years ago), and the forks can still be had.
    Are these the right type/size?
    Amazon.com : eXotic Rigid Alu MTB Bike Fork Disc Specific 46.5cm for 29er or 650b front wheel : Sports & Outdoors
    Is that a good price? Are there alternatives that might be a better value for less?
    And am I correct that the current forks on the Rockhopper are post-mount, and that these eXotics are IS mount and would require an adapter?
    Thanks ahead of time. It's nice as a novice to be able to tap into gigantic bike-brains.
    You will need an adapter for IS mounts if your current bike doesn't have them already if you don't have/get calipers that are IS mount. Even then you may need adapters.
    Kona Big Unit SS
