Results 1 to 3 of 3
    Reputation: c0nsumer's Avatar
    Rigid Fork with 15mm TA?
    Do any of you know of a rigid fork that's available with a 15mm TA (and a tapered steerer if possible) besides the Niner RDO?
    I'd love something a bit cheaper and maybe steel like a Salsa, but they currently only make a 20mm TA version.
    Feb 2012
    I assume you want a tapered steerer tube? I asked the same question a while ago, didn't find anything besides the Niner RDO.
    29er rigid fork with tapered steerer and QR15?
    Riding rigid
    If your wheels are convertible, then get the salsa $199 and get the correct caps (~30). It would still be less than the carbon offerings from Niner ($550) and Whisky ($650) with 15mm. If you are stuck on 15mm, Walt works will weld up a steel fork for about $375.
