Results 1 to 5 of 5
    Rigid 15mm TA Fork
    Anyone know of a non-custom rigid 15mm TA fork that has a non-tapered steerer tube? The only ones I am aware of are have a tapered steerer tube. And, if not now, any industry guys know if there are any in the works for 2013?
    My front hubs are convertible with some effort, but I want to be able to switch back and forth with minimal hassle. My WI hubs require changing the axle and bearings. It is not a simple swap of the end caps like some hubs.
    Reputation: WarPigs's Avatar
    Dec 2005
    jmal, what are the ones that you mentioned? i.e. with tapered steere tube? I am also interested in a similar fork, but built to emulate a 120mm 29er fork.
    Si Vis Pacem, Para Bellum
    Thanks Perfect Gent. How is the quality of these forks? Anyone have first hand experience with them?
    WarPigs: I don't know about 120mm forks, but Niner RDO forks are available in 15QR with a tapered steerer.
    Aug 2010
    jmal, both of them are rather famous British companies. quality is very good.
