Results 1 to 20 of 20
    Jul 2013
    Replacement cranks
    I have a Trek Stache 7. And because I am a noob, when attempting to remove the pedals and install clip-less I wrenched the left pedal the wrong way. Even with the help of the shop the pedal could not be removed. If I were to replace the cranks as a possible solution, is there a recommended upgrade or should I just replace the cranks set and/or crank arms with the same:Race Face Ride, 38/24 w/turbine outer ring?
    Reputation: Epic_Dude's Avatar
    May 2010
    Hard to believe the pedal cannot be removed. Take the crank (or crank arm) off the bike, wrap a rag around it, put it in a vise and using a pedal wrench give it a few good whacks in the right direction. Should loosen, and you won't need to buy new cranks.
    Unless you WANT new cranks...
    What could go wrong ...
    Reputation: Zoke2's Avatar
    Nov 2007
    can the shop get you a left crank arm
    I used to ride to Win ... Now I ride to Grin
    While my guitar gently weeps, my bike sits there mocking me
    Jul 2013
    The pedal bolt head was essentially stripped from trying to take if off, so the pedal wrench is retired at this point. Ended up trying a vise-grips (stripped bolt head) and a 6mm hex head (on the inside) at the same time and still wouldn't budge. Other options presented were a torch and/or drilling it out. Neither of which is available to me. Didn't request a left crank arm from the shop, so I could check that out.
    El Gato Malo
    Remember that you'll have to buy replacement pedals too.
    May 2010
    Yep, if you stripped out the internal hex on the pedal it's easier just to replace the crank (or crank arm if it's that side) and pedals.
    A.D.D. unleashed
    Re: Replacement cranks
    Cut pedal off with as much of the spindle as possible , weld long piece of scrap steel to remaining spindle put the arm in a vice and unscrew it
    Sent from my Galaxy Nexus using Tapatalk 2
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    If OP can't even access a torch, much less a drill.....how is he gonna weld something to it?
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Sometimes when a hex bolt is stripped you can get a torx to work. Use a piece of pipe over the wrench to get more smooth torque. Hitting with a hammer strips much easier
    Sent from my SAMSUNG-SGH-I747
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    Sears often has tools for this kind of stuff.
    http://m.sears.com/productdetails.do...r=00952154000P
    I just pasted this into another thread - its for screw extraction, but they might have something like this for larger size hex bolts too.
    Sent from your phone, which i hacked into
    > /dev/null 2&>1
    Feb 2012
    Maybe these are for hex, product title says hex, but description doesn't.
    http://m.sears.com/productdetails.do...ullFillment=VD
    Here is a better pic, looks like it might work:
    http://www.irwin.com/tools/screw-bol...stic-case-sets
    These are designed to extract counter clockwise. Luckily its your left pedal, which should loosen CCW when using the hex bolt on the inside of the crank.
    Jun 2013
    It looks like your bike comes with a heavy and flimsy bottom bracket and crank assembly, good time to upgrade.
    If you want to salvage the thing, one thing to try is to hammer a size larger 1/2" drive Torx socket into the hex on the back of the pedal, and use an impact wrench counterclockwise/loosen direction from the back side.
    I know you don't have access to a torch but you can even do this with a lighter...
    Put the pedal in ice and heat the crank up - a torch is nice but you could use a lighter or propane torch ($16 home depot). This is how I got header bolts out of my car and it worked when all else seemed to fail...
    Reputation: Jakerz's Avatar
    Jun 2013
    Remove the crank off the bike and stick it in a vice (use a rag to keep from scratching it) and go buy a cheap 6 inch pipe wrench from Harbor Freight. The find a piece of pipe (Home Depot) that will fit over the end to use as a cheater pipe. Trust me it will come off with a pipe wrench lol.
    Jake
    Reputation: Pauldotcom's Avatar
    Aug 2010
    Get a shiny new SLX crank for $99 with BB and consider it a nice upgrade.
    “People fear death even more than pain. It's strange that they fear death. Life hurts a lot more than death." JM
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    My $0.02:
    Get these:
    Race Face Evolve 2X10 Cranks 2012 Oe > Components > Drivetrain > Cranksets | Jenson USA Online Bike Shop
    They will slide right in, and they are the same chainring size as stock.
    Jul 2013
    Finally got it with the help of my brother and his impact wrench and a vise grip. Cranks were not damaged. It was tough, sheared a one of the hex bits trying. Thanks.
    Quote Originally Posted by Sweetwater Jones View Post
    So, you cross threaded right handed threads (right pedal) into left handed threaded hole (left crank) and the crank threads were not damaged?
    I have seen people do this several times, the crank arm is toast. The pedal is toast. You should be able to buy a left crank arm through your LBS. However, you have to buy 2 new pedals.
    Easy way to remember which way pedal threads - put the pedal in the hole, hold the pedal spindle, and spin the cranks backwards.
    Jul 2013
    Quote Originally Posted by crit_boy View Post
    No, just turned the peddle too tight trying to take it off (the wrong way) and tightened to the point of stripping the bolt (turning it the correct way) once I realized what I was doing. I did not cross thread the new peddles.
    Oh, I misunderstood what happened. Odd that the shop could not get it out. As post 2 said, putting the crank in a vise should have done the trick.
  1. Replies: 2
    Last Post: 05-06-2013, 12:38 PM
  2. Shimano XTR Trail 2x10 cranks/ring replacement and compatability
    By Cato in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-04-2012, 01:52 PM
  3. Replacement Rings for SRAM S-2200 Cranks?
    By onepivot in forum Specialized
    Last Post: 11-29-2012, 10:26 PM
  4. Truvative XX cranks and Shimano XT cranks- Chainguide?
    By hiawatha-de in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-24-2012, 09:31 AM
  5. Shimano M737 cranks vs M950 cranks!
    By cyberbackpacker in forum Singlespeed
    Last Post: 12-15-2011, 12:23 PM
