Results 1 to 34 of 34
    Jul 2013
    Removing the arch of a front suspension fork
    What would happen if the arch of a front suspension fork was to be removed?
    Sent From My Rotary Phone
    Reputation: Ryandurepo's Avatar
    Nov 2012
    Bad things would happen. Not to mention how much flex your fork would have.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Quote Originally Posted by tugofwar View Post
    Hilarity would ensue.
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    The legs would operate independently... which would be really funny on forks where one side is the spring and one is the damper.
    Try it and post vid.
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
    ballbuster
    Reputation: pimpbot's Avatar
    Quote Originally Posted by meltingfeather View Post
    ... Which is pretty much all of them.
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    OP - please make a short GIF of the result.....
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    The Original Suspect
    Reputation: HitmenOnlyInc's Avatar
    Is there a sticky for Most Ridiculous Thread Questions EVER? If not, this should be the first one.
    Only if you want to crash in the worst possible way. Please don't do this unless you want to be a YouTube FAIL sensation.
    -Nolan
    Reputation: Joules's Avatar
    I don't see any problem that could come of it. I mean, you probably have a better understanding of what's needed for your fork to work properly than they guys that designed it, right?
    RIP Friendgirl
    Reputation: Bordershy's Avatar
    It would become a Marzocchi single crown Shiver. Google it
    SPD pedals are an absolute menace to the well-being of the world, and ought be banned immediately.
    Sep 2012
    Don't let all these guys mess with you OP. You will lose about 2lbs of weight on your Wal-Mart Mongoose and could easily do the Redbull Rampage next year. Stanchions are overbuilt for this reason specifically.
    I believe in you brah.
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    Re: Removing the arch of a front suspension fork
    No, no, no, you don't just remove those. For better performance, you just wanna reattach it lower, below the rim.
    Jul 2013
    Cutting off the arch has not affected performance at all. The only reason i removed the arch was to accommodate the 32" front wheel on a beach cruiser.
    You are full of it.
    Post vid.
    What beach cruiser has front suspension, and what is "performance" on a beach cruiser?
    Crash Dummy In Training
    Reputation: PauLCa916's Avatar
    Jun 2013
    Performance on a Beach Cruiser = Beer Holder plus rear rack to carry ice cooler.
    OP Take two pieces of Spegetti and place them in boiling water for 5 minutes then pull them out this is how your fork's will be.
    2015 Flyxii / ENVE /Chris King Carbon 29'er H.T.
    SRAM XX1
    2012 Stump Jumper Comp 29'er H.T. SRAM XX1
    1997 Rock Hopper / Rock Shox Recon Silver / 1 x 10 SRAM X9 XO Mix XT V Brake system
    Dec 2010
    Subscribed
    Sent from my SCH-I535 using Tapatalk 2
    The Fastest of Bananas
    Reputation: FastBanana's Avatar
    Aug 2013
    Bwahahahhahahahaha!
    Sent from my EVO using Tapatalk
    Props to OP for playing along! Rep sent!
    On wuss patrol
    Reputation: Glide the Clyde's Avatar
    With a through-axle fork, it should work fine, especially with the added stiffness of a 20mm axle.
    Sometimes, you need to go fast enough that the trail is a blur to find clarity. -- Wild Bill
    Aug 2013
    If this was in WeightWeenies, it would n't be a joke
    Jul 2013
    You are full of it.
    Post vid.
    The ones that i build from scratch :P Videos are forbidden here in Russia
    It is impossible to build beach cruisers from scratch. They are intellectual property owned by Walmart-McDonalds-Goldman Sachs
    Jul 2013
    WTF is a "walmart"?
    AZ
    AZ is offline
    Ahhhh, the until now secret triad that acts as the enforcement arm of the Illuminati
    Reputation: bbbr's Avatar
    your Ortho gets to make several payments on his yacht???
    Alea Jacta Est
    WTF is a "walmart"?
    If you don't know then you obviously haven't built a beach cruiser with front suspension.
    Jul 2013
    So upon further investigation and positive input, i have decided to fabricate an arch big enough to clear the 32 " front wheel and then weld it on the same area where the original arch was welded on. NBD
    Reputation: Kiwiplague's Avatar
    I detect the subtle hint of troll about you
    I don't crash, I just have slightly uncontrolled dismounts!
    Make sure you use magnesium welding rod.
    You already cut it out and saw no effect on performance. If it ain't broke...
    Reputation: mitzikatzi's Avatar
    Quote Originally Posted by Bordershy View Post
    Weaknesses: way too much flex. managed to snap one of the upper stanchons. these forks need a brace or something. suprisingly enough marzocchi have reduced the travel for their newer forks, probably because they know there's a problem.
    Weaknesses: -no stiffer than over-cooked spaghetti
    -less travel than other "freeride" single crown forks
    - pressfit crown and lowers
    Bottom Line:
    This is an absolutely terrible product; it has been a success because of it's marketing, not it's engineering. The idea that a fork with narrow, 30 mil stanchions and a non-existent brace could be stiff encough to corner well through rough terrain is ridiculous. In fact,the fork requires its riders to develop a modified style of riding: learn a trail, know exactly when all corners are approaching, and start turns while riding buddies with z1's and shermans are still accelerating.
    from here
    Yes Shiver indeed
    Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
    Jul 2013
    Quote Originally Posted by Kiwiplague View Post
    Actually I was asking because i have never had experience using a front suspension fork, let alone altering one like cutting off the arch. Since i never got any hits using Google search, I decided to ask here. Some of the responses i received here were of the "you shoulda known" nature. After lubricating the front shocks, they became wobbly so i decided to fabricate an arch to accommodate the 32 inch front wheel and all is well. Now I know the purpose of an arch and have learned how to lubricate a front suspension fork
    Sep 2012
    I want to see pics of your fabrication.
    Jul 2013
  1. Fenders on a front suspension arch
    By brenton in forum 29er Components
    Last Post: 08-01-2013, 07:12 PM
  2. Upgrading front fork/suspension - need help
    By k_singh in forum Beginner's Corner
    Last Post: 11-11-2012, 03:25 PM
  3. Replies: 4
    Last Post: 09-13-2012, 01:33 AM
  4. SR Suntour XCT V3 Front Suspension Fork?
    By Big C in forum Shocks and Suspension
    Last Post: 07-31-2011, 10:50 AM
  5. Mercalli downhill front suspension fork
    By SGP495 in forum Beginner's Corner
    Last Post: 07-20-2011, 02:12 AM
