Results 1 to 7 of 7
    Jun 2012
    recommend me a rear wheel for my xc bike(29er) 950 element.
    I want to have a spare rear wheel.
    Looking to spend: middle of the road
    Rear wheel only 12x142 mm.
    I weigh with gear around 250lbs, most of it is cross country miles(2500/year)
    Very little jumping, no drops.
    Not sure if I need tubeless, had one flat in 7 month.
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    At 250 lb go for a Flow, they are light for how strong they are & you can run it tubeless
    Tubeless is very good & not just for not getting flats.
    Quote Originally Posted by Learux View Post
    Nov 2008
    I agree. At 250lb it's not worth the risk running a lightweight XC wheel. I'd say either the flow or charger would be a good compromise between stiffness and strength. They are a much better wheel then the price would reflect.
    Carbon & Ti rule
    Quote Originally Posted by drz400sm View Post
    I have got many sets of chargers & at my 185 Lb climbing steep pinch climbs I can make the free hubs groan & make horrible sounds, So at 250 Lb I would stay away from them & any other wheel that has less than 32 spokes.
    Just my 2 c
    I would look at a FlowEX rim, DT 350 hub with 36 tooth ratchets, DT Comp spokes with brass nipples. Lace it yourself with a Park TM-1 tension gauge. Or lace it and get it trued and dished at your LBS.
    It would be about 100 more for a LB wide carbon rim.
    Reputation: Mr. 68 Hundred's Avatar
    I like:
    WTB » Products – Wheels – Rims – 29er – Frequency i23 TCS 29
    Would have gone with it myself if it was just a bit wider. I agree with eb on hub/spokes/nipples. And tension guage for that matter. Hopefully your LBS has the spokes you need in-stock, because buying them online is a PITA.
    Feb 2013
    XT 765 36 holes hub, mavic TN719 rim, DT Alpine III spokes and brass nipples
Hot Deals
Contests
Latest Mountain Bike Articles
