Results 1 to 7 of 7
Thread: Reba Rl
    Reputation: larryarroyo's Avatar
    Mar 2012
    Reba Rl
    Insalled a new reba rl, but when i try to compress it while holding on the front brake to check the sag and compression, i could hear something like an air sound, is it normal? My 1st dual air, so have no idea. Thanks
    Reputation: Epic_Dude's Avatar
    May 2010
    When I ride my new Reba RLT (dual air), I hear a pshh sound each time the fork rapidly compresses. I think it's normal. I also get a film of oil (and dirt) on the stanchions, again I think this is normal. I just make sure I clean the stanchions before each ride.
    Reputation: SlowPokePete's Avatar
    Mar 2006
    Sounds normal to me.
    SPP
    Rigid.
    Kitty! Kitty! Kitty!
    Reputation: GelatiCruiser's Avatar
    Oct 2012
    Re: Reba Rl
    If it's a "whoosh" sound it's just the rebound. Totally normal.
    Reputation: pitworkz's Avatar
    Jun 2013
    mine too..as the fork compresses..it made a swish sound. Just like my tein coil over on my car.
    Rep'n the 905
    Jun 2012
    Its the speed in which your shock is compressing. At the bottom of your front shock theres a dial you can spin to have the shock rebound faster or slower. The more slower its set the more of that "pssshhhh" sound you get. Or at least on mine thats how it was.
    I had it running all the way fast and it was silent, I went more slower of a rebound now and I get that sound
    Jun 2013
    With Poplock closed reba rl and rlt are very stiff or fork go down? If yes how many millimeters go down?
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Quote Originally Posted by jonny89 View Post
    With Floodgate fully dialed open....no more than 10mm TOPS.
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
  1. Replies: 55
    Last Post: 04-10-2015, 01:57 PM
  2. Convert '11 Reba RL 9mmQR into '12 Reba RL 15mm?
    By KBfromVT in forum 29er Components
    Last Post: 08-11-2012, 09:20 PM
  3. 15mm Reba lowers on Brain 9mm Reba?
    By Le Duke in forum Shocks and Suspension
    Last Post: 12-21-2011, 06:13 AM
  4. newer (09-11) Reba damper in older (05-08) Reba?
    By aosty in forum Shocks and Suspension
    Last Post: 08-31-2011, 05:54 AM
  5. Replies: 0
    Last Post: 03-15-2011, 08:27 AM
