Results 1 to 13 of 13
    unrooted
    Reputation: unrooted's Avatar
    Reba 29 QR-9mm to 20 maxle light conversion
    My 2010 Reba 29 is in need of an overhaul, the bushings have a ton of play in them. I would love to just buy a new Fox fork, but not for $700???
    My bike has a 1 1/8 headtube so I'll just wait till I can afford a new bike.
    I want to buy this: 09+ Reba 26" Maxle Thru Axle (Black)
    This: Rock Shox Maxle Lite 20mm Fork Axle
    This: Stans ZTR Arch EX Tubeless 29" Wheelset - 2013
    And these: 20mm End Caps for 3.30HD Hub
    Does anyone have any experience doing this??? Seems relatively simple. The only additional thing I would need is whatever tools and hydraulic fluid. I think.
    This would still be expensive, but I think I can afford the sub $1,000 job compared to the $3,000 bike I would rather have.
    May 2013
    I wouldn't waste your time. For the price of the lower your could buy a slightly used but serviceable fork.
    Reputation: Joules's Avatar
    It is pretty easy, and the lowers coming with new bushings and seals is a nice touch. Only tools you really need are standard hex keys, a couple sockets and snap ring pliers (which aren't totally necessary but make the job much easier). You'd be getting a basically new fork for $250 + fluid, and the maxle is worth every penny.
    Those wheels seem a bit pricy for what they are, to me, but whatever wheels would work.
    unrooted
    Joules,
    I wouldn't pay those prices in the links, just what I was thinking would be a decent set of wheels. What wheelset would you suggest. Are most of the higher end wheels convertable to 20mm? I would like to buy a set of wheels that are better than what I'll get with a $3-$4000 bike so that when I do get a new bike I still use them, or I'll put them on my wife's bike.
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    CRC has the Arch EX wheels much cheaper & with the Hope Pro 2 EVO hubs as well.
    Quote Originally Posted by unrooted View Post
    I have a 6 Berth & 2 Berth Motorhomes that I rent out . They are based in Tauranga, New Zealand
    unrooted
    Muzzanic,
    What is CRC??? I can't seem to find any online shops with those initials
    unrooted
    OHHH, Chain Reaction... I bought some stuff through them a few years ago and the exchange rates they advertise are much better than what my credit card company charged. I felt totally raped. maybe they are better now?
    The Arch EX wheelset can be had for about $400 on ebay. I don't believe the hub on the stock wheelset is convertible to 20mm, though. You need the 3.30HD hub for that. To have a 20mm option, look for Arch EXs laced to Hopes.
    Carbon & Ti rule
    They have been good to me.
    I'd still recommend you buy a new fork over trying to rehab the Reba. You're also likely going to need new seals in the damper/air spring if it's used to the point of bushing wear. You'll also likely find the hard coat on the stanchions is getting worn. You can pick up an X-fusion Slide from Universal for $340 with the VIP15 code. I know it's a little more money, but it's a great fork with a warranty.
    CRC has treated me well in the past. I believe if you select USD as the price format it will charge your card in USD.
    Here's the ArchEx front wheel only for $215. Get a 15mm lower. Check with Sram.
    NoTubes ZTR Arch EX 29 clincher front wheel 29"
    Go a little lighter and cheaper with a Novatec D711 hub off ebay, Supercomps/brass nips and an ArchEx in your own laceup. about 130. plus endcaps.
    meow meow
    Reputation: b-kul's Avatar
    i agree, if you go that route get 15mm qr. a little worse but the maxle system is pretty good and 20mm seems to be going away for all but the gravity stuff.
    unrooted
    If I swap the lowers I have to stick with 20mm because rock shox didn't make 15mm for my fork. I would prefer to just get a new fox fork, but I don't want to spend a lot on a 1 1/8 fork. I think I'll just wait and see if I can afford 3k for a new bike.
  1. Maxle conversion
    By shreddr in forum 29er Components
    Last Post: 06-17-2013, 08:46 AM
  2. 2013 Reba Rl/RLT with a maxle??? Is it possible to get one?
    By WillT19 in forum Shocks and Suspension
    Last Post: 06-03-2013, 03:46 PM
  3. Spam: Reba RLT Ti Tapered Maxle $225
    By Enel in forum 29er Bikes
    Last Post: 08-10-2012, 09:47 PM
  4. Reba lower with 15mm Maxle light
    By anesthesia-matt in forum Shocks and Suspension
    Last Post: 07-06-2012, 05:43 PM
  5. I just got a new Reba 29 RL Ti 140mm Maxle lite
    By Lucid in forum Shocks and Suspension
    Last Post: 01-11-2011, 11:16 PM
