Results 1 to 11 of 11
Thread: Rear mech ?????
    Jun 2013
    Rear mech ?????
    Notice a lot of the 2x10 builds use the long cage rear mech. I read med cages could be used for double chainrings. I want to use the med cage for my build. Is this a problem?
    Using a medium cage on a triple will work for all gears except the small front and the smallest about 3 rear. You will not have enough derailleur scope to take up all the slack. You won't be snapping a chain. If you don't shift into those gear combos you will be fine. This is for advanced riders. So no problem for a double.
    29ers Forever
    Reputation: CannondaleF9's Avatar
    Nov 2012
    My understanding is that the medium cage is for 2x10 and the long cage is for 3x10.
    Reputation: Nater's Avatar
    shimano medium cage does not officially have enough range to handle a typical 2x10 spread of about 27T. The medium cage I believe officially can handle up to 25T of spread. Im running a medium cage with 27T of spread. Theoretically it will be too slack on small/small but it seems fine. In any case I never use that gear combo anyway.
    Reputation: shiggy's Avatar
    Dec 1998
    Rear mech ?????
    Quote Originally Posted by goodmojo View Post
    Wrong. Shimano medium cage mtb RDs (GS) have a 33-35t total capacity.
    The Zee and Saint are short cage (SS) with a 25t capacity.
    mtbtires.com
    Jun 2013
    Cassette I plan to use is XT 11-36 cassette? Chainset will be XT double 26-38. So will it work on a Med cage? First build so I want to get it right. If not , going to 11-34 cassette should do it....right? I have not seen any 29ers built with an 11-34 cassette !!
    the WALKING DEAD
    I built my bike up with a an XT drivetrain. 11-36 cassette, 26-38 double crank, and med cage Shadow + derailleur. It works perfect.
    Your momma's so nasty, she keeps ice between her legs just to keep the crabs fresh.
    Jun 2013
    Thanks for the info aph. That momma joke is hilarious....ja,ja,ja !!
    Just saw this thread and was planning on going Shimano 1x10 using 30T (Wolf) front and 11-36T cassette. Which rear derailleur would work best, GS or SGS for this type of set up? Thanks!
    With a single ring, you can go short cage.
    I'm running 11-36 tooth cassette with a MRP 30 tooth Bling Ring and the Zee SSW short cage free ride rear derailleur. Works great.
  1. XT or Zee rear mech for 1x10?
    By CrozCountry in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-26-2014, 02:41 PM
  2. Old XT versus new SLX rear mech?
    By biggrumble in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-03-2012, 03:57 PM
  3. New Saint rear mech
    By Qcamel in forum All Mountain
    Last Post: 07-06-2012, 10:19 AM
  4. Alfine vs Rear Mech
    By druidh in forum Fat bikes
    Last Post: 01-27-2012, 11:34 AM
  5. Rear Mech Reign X1
    By rondet in forum Giant
    Last Post: 02-01-2011, 08:10 PM
