Results 1 to 11 of 11
    Jan 2013
    Which Rear Derailleur?
    I need to get a new rear derailleur for my wife's bike and I was looking at competitive cyclist and they have a good deal on a Shimano XT. Is it possible to just throw that on the bike even though it has full X7? If so is it worth it, or should I just get an X7?
    Rear Derailleur
    Shimano XT Dyna-Sys RD-M781 Rear Derailleur - Competitive Cyclist
    Bike Specs (it has an X7 front derailleur)
    2011 X-Caliber WSD - Bike Archive - Trek Bicycle
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by BrianVarick View Post
    Rear Derailleur
    Get another SRAM 10-sp RD
    You can not mix Shimano rear derailleurs and SRAM shifters or vice versa.
    mtbtires.com
    Jan 2013
    ^Oh ok, that's good to know Is there anyway to know whether her bike had a short medium or long cage?
    Typically if it has a triple crank on it, then get a long cage. If it has a double or single then a medium usually would work. Short if she has a single chainring and smaller range on her cassette (no bigger than 28 or 32ish)
    Reputation: Bigb2000's Avatar
    May 2013
    Price the x9 type 2 RD. It's really quite and quick enough for about anyone. I run it with x7shifters and have had zero issues. Not sure the price difference of x7, if its close go with x9.
    Reputation: mitzikatzi's Avatar
    Quote Originally Posted by manbat View Post
    Im not trying to overcomplicate things BUT what about derailleurs for 11/36 cassettes....
    From The derailleur at CC link
    The length of the cage determines the overall chain-wrap capacity, or more simply put, how big of a tooth difference it can accommodate between the biggest gear and the smallest gear. Total difference can be found with this equation: big ring - small ring + big cog - small cog. For example, the long cage (SGS) option will work with a 24/32/42 tooth chainring configuration (18t difference) plus an 11/36 cassette out back (25t difference). This meets the maximum chain-wrap capacity of the long cage derailleur at 43t. The Short length cage (GS) has a chain-wrap capacity of 35t and could be used for a single or double ring/bash-guard set-up as the 11/36 (25t difference) plus the 24/32 chainring (8t difference) does not exceed its range.
    Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
    XT shadow+.
    Dec 1998
    Any 10-sp long cage SRAM.
    mtbtires.com
    Dec 1998
    Quote Originally Posted by hammy56 View Post
    XT shadow+.
    Ummm...no. You need to pay attention.
    mtbtires.com
    oops. lol.
  1. Replies: 5
    Last Post: 05-11-2013, 05:16 PM
  2. Replies: 0
    Last Post: 03-28-2013, 04:05 AM
  3. Need help! rear derailleur
    By lilcrate in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-23-2012, 01:51 PM
  4. Will an X0 rear shifter work with a Red rear derailleur?
    By Jonnybravo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-16-2012, 11:12 PM
  5. Replies: 5
    Last Post: 04-08-2011, 07:09 PM
