Results 1 to 16 of 16
    Jun 2013
    Rear derailer for 1x10ish setup
    Any specific derailers work better for a 1x setup? I know you want a short arm, but didn't know if there was anything more than that.
    Sent from my XT907 using Tapatalk 4 Beta
    Reputation: Epic_Dude's Avatar
    May 2010
    Definitely either a Shimano XT, XTR Shadow Plus or SRAM X9, XO, or XX Type 2 derailleur depending on your budget and if you like Shimano or SRAM.
    Reputation: Johnnydrz's Avatar
    If you don't want to spend XTR-ish $$$, go for Shimano ZEE. That's what I did and I've been impressed so far. In the past, (too many years to count...) I always went with XT or X9. I have ZERO complaint about the ZEE stuff.
    Shadow +, SLX or XT.
    ZEE is Shadow + (clutch!). No chain guide and no chain slap/drop.
    Jun 2013
    What is a clutch in mt bike?
    Shimano ZEE
    Quote Originally Posted by TheRoweShow View Post
    Shimano ZEE Shadow Plus RD-M640 FR (Free Ride version) (Fits 11-36T cassette)
    It has a friction clutch and resists forward motion of the derailleur cage, which helps keep the chain under better tension for less chain slap in rough terrain. It works. Just switched from a SRAM X0 rear derailleur and X9 shifter.. Hated the upshift resistance of the SRAM, so friggin hard.
    The Shimano Saint SL-M820 shifter I have paired with the ZEE derailleur is MINT. Easy perfect shifts like my old Shimano XT 9 speed setup.
    squish, squish in da fish
    Reputation: fishwrinkle's Avatar
    +1 on the zee, durable & cheap. outta the box to the trail in an hour. very lil tuning to get dialed and havent touched it since. have about 250 miles on it with a couple direct hits off rocks. takes a lickin' n keeps on tickin'. i paid 90 for mine and havent regretted it. i use the zee shifter and no complaints there either. nice crisp sound shifts. i did lose the cover and when i asked jenson how to go about purchasing a new one they sent me a new shifter. what a surprise that was. i do use a tensioner with it but thats just so i get extra chain clearance. def not needed or a guide like said before
    A few of my bikes have the ZEE 11-36 compatible, and with my XTR rear shifter it's a perfect 1x10 spec. Less than $80 online at some places. I have XTR mid and long cage on other bikes, and beside the 50 gram difference I can't tell which is which in performance when set up with a clean cable and housing.
    Reputation: Shalom's Avatar
    Nov 2008
    Quote Originally Posted by westin View Post
    This
    I'm just messing with you
    Reputation: wv_bob's Avatar
    I'm looking hard at going with a Zee rear der with an SRAM X-7 shifter so I can still run my 9speed parts.
    Yesterday I apparently kicked the chain off in some rocks, then immediately after went to trounce the pedals to get on up the hill. The chain/crank didn't budge and the bike rotated around the front wheel until my public triangle encountered the too-long steerer tube above my stem. At least I didn't endo. The Zee should help with that problem.
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
    Nov 2008
    Are you sure you can run the zee rear mech with a sram shifter? Never have been able to get a shimano and sram mix to work, ive tried just for sh*** and giggles. Im not sure if the zee has a different design..is the actuation different on the zee/saint shifters? Im only familiar with xt/xtr and srams x9/xo/xx.
    Jun 2012
    I have a POS X4 here and it even uses SRam 1:1 shifting, I dont thing it will work with a shimano derailleur, but I have never tried it. Give it a whirl and report back your findings
    Reputation: brmeyer135's Avatar
    Mar 2013
    Front derailleur you can mix the brands, the rear you can't, at least not with good shifting. It has to do with the movement distance with a click of the shifter.
    Quote Originally Posted by drz400sm View Post
    Yeah it's the key to using 10 speed Shimano with 9 speed parts. Shimano 10 speed has 1:1 actuation. I might need a spacer to move the cable anchor a little, but some have reported no need with the Zee. See link below
    in Kensington, Maryland, United States - photo by jwick - Pinkbike
    Quote Originally Posted by brmeyer135 View Post
    Typically yes but in the case of 10 speed vs 9 speed, no.
    Despite my appearance I am not stupid.
    Update: Just installed a Zee derailleur with an SRAM 9speed shifter and it works. It's was kinda touchy without the 6mm cable mount spacer mentioned in other threads/websites so I spent $1.25 at the hardware store to fix it, with parts leftover I grooved a 1/4" square nut, put it on a washer, added a longer bolt (m5x12mm) and the factory cable retainer. The nut doesn't exactly fit the recess in the derailleur so I reached in from the other side with a 1/2" open end wrench to adjust/hold the nut so it ended up with the cable lined right up to the factory groove. EZ to do, and works like it came from the factory as a 9 speed setup.
  1. Rear derailer not staying.
    By jeepnphreak in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-27-2012, 07:26 AM
  2. Rear Derailer question
    By Over50rider in forum 29er Components
    Last Post: 05-04-2012, 09:07 PM
  3. Busted rear derailer, 1st run!
    By Tim F. in forum Downhill - Freeride
    Last Post: 04-10-2012, 06:35 PM
  4. Two problems. Rear derailer, rear shock
    By Petti the Yeti in forum Tooltime
    Last Post: 07-03-2011, 08:14 AM
  5. Rear Derailer?
    By B-RAY in forum 29er Bikes
    Last Post: 03-06-2011, 03:30 PM
