Results 1 to 8 of 8
    May 2013
    Race Face Race XC X-Type BB
    Race Face 2013
    Anyone know if this would fit a ironhorse sinister 6.2?
    May 2013
    I know i have a standard square shimano type Crank on the bike now from pro-wheel
    It will probably fit but since it's a full suspension you should check the width of the bottom bracket shell and the current chain line before picking out a crank.
    May 2013
    Well I would try to use the crank I have now, untill I upgrade that. I was told first thing I should upgrade is the bottom bracket on the bike to a sealed unit.
    Reputation: MrPretty's Avatar
    Feb 2012
    I'm not 100% sure, but according to the internet, that crankset appears to be a Square Taper unit. Which means you would need a Square Taper Bottom Bracket (not an External Bottom Bracket), unless you want to replace your crankset too.
    is this your bike?
    Sinister 6.2
    if it is, searching the crankset I found this
    MA-A443+ | Prowheel
    which is where I got the square taper from.
    Reputation: dbhammercycle's Avatar
    Quote Originally Posted by 208Ryder View Post
    The x-type bb is an external bearing bb which works with a thru axle crankset. It will not be compatible with your current crankset. That said, it should fit in your bb shell. It will fit 68-73mm bb shells with or without the use of spacers.
    I don't know why,... it's just MUSS easier to pedal than the other ones.
    May 2013
    wow this gets kinda convoluted with all these different types and what not.
    But I get it now. Thank you. Just saved me from buying something that wouldn't work.
    You guys are awesome. I found a thread here on the forum talking about ST BB and EXT BB and the differences. So I see where some people differ on the point of view.
    So Im thinking I might need to measure to find out the mm of the shell BB. Ive had multiple people tell me 68 but no definite answer. So ill have to get a ruler.
    That bottom bracket will fit the bike but won't work with that crank.
  1. Race Face X-Type BB Compatible With Stylo?
    By onepivot in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-24-2012, 10:39 AM
  2. Replies: 4
    Last Post: 03-24-2012, 10:11 AM
  3. Race Face X-type BB making terrible grinding noise
    By Varaxis in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-06-2011, 12:51 AM
  4. race face x type ?'s and carbon one
    By 1362 in forum Rocky Mountain
    Last Post: 06-21-2011, 08:14 AM
  5. Race Face X-type bottom bracket replacement
    By adrianfleming in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-01-2011, 03:45 AM
