    Question about forks: Have a Scott Scale 29 Comp...
    what do I need for a tapered QR15 fork?
    Another frame. That one takes a 1-1/8" steerer. 15mm can go on a 1-1/8 straight steerer fork if you want to buy one like that. You would need a wheel with the axle and endcaps to fit that. Some come with changeable endcaps.
    If you want to upgrade your Suntour fork
    pretty sure the headtube on those is a ZS44 headtube, which means you can in theory run an EC44 cup and your tapered fork, but it'll raise the headtube about 10mm. You are, in theory, better off with the ZS setup, but tapered is so much stiffer. If you can deal with a half degree slacker headtube, you'll be OK, I think.
    https://www.canecreek.com/headset-fit-finder
    Reputation: TwoNin9r's Avatar
    Jan 2011
    My uncle runs a scale with a 115 fork (which raises the ht about the same amoint) and he absolutely loves it. So the slight slackening might be a welcome change.
    Posted via mobile
  1. Scott Scale 29 Comp is equivalent to?
    By zephxiii in forum Scott Sports
    Last Post: 10-01-2012, 06:56 PM
  2. Scott scale 29er comp?
    By 417brobinson in forum 29er Bikes
    Last Post: 07-22-2011, 07:12 PM
  3. Scott Scale 29 Comp
    By dodgeball2d in forum Scott Sports
    Last Post: 05-04-2011, 08:37 PM
  4. Giant Revel 1 VS Scott Scale 29 comp
    By dodgeball2d in forum Beginner's Corner
    Last Post: 04-20-2011, 06:56 AM
  5. Scott Scale Comp, opinions
    By JHoutchens in forum 29er Bikes
    Last Post: 03-14-2011, 11:32 AM
