    purgatory 2.4 on a 24 mm id rim
    I like the purgatory 2.4 set up on my 35mm velocity wheel set. I'm wondering if they will fit on the rear of my new enduro with 24mm inside width rear rim. Anyone have some measurements on a 24mm or so inside width rim?
    <100%
    Reputation: JackJr's Avatar
    maybe not relevant but I am running a 2.4 purgatory on Mavic 819's (26 of course) on my Enduro without any problems - plenty of clearence in the rear, just barely fits inside the E-150 though....
    Reputation: Ronnie's Avatar
    If it helps I have a Purgatory 2.4 on a Sun Ringle Charger rim which has 22.8mm. internal width and NoTubes BST. The NoTubes BST means that the rim bead hook is much shorter than most other rims allowing more of the sidewall outside the rim. The tire width is 61.5mm at the widest point with the pressure at 24psi.
    By the way, if you're not aware, the Purgatory 2.4 is no longer available.
    The trouble with having an open mind is that people will insist on trying to put things in it.
    Thanks, ^, they are available in my own garage store :0)
  1. Purgatory cut, thoughts?
    By LyNx in forum Specialized
    Last Post: 04-30-2013, 09:44 AM
  2. Purgatory 2.3 or 2.4
    By HrznRider in forum Wheels and Tires
    Last Post: 12-26-2012, 06:54 AM
  3. Purgatory 2.3?
    By dgw2jr in forum Wheels and Tires
    Last Post: 09-26-2012, 08:27 AM
  4. Replies: 4
    Last Post: 12-19-2011, 12:51 PM
  5. purgatory sold out?
    By dan0 in forum Specialized
    Last Post: 11-17-2011, 07:25 PM
