Results 1 to 5 of 5
    29ers Forever
    Reputation: CannondaleF9's Avatar
    Nov 2012
    Problems with X5
    After going out for a first ride on my 2013 Trek Cobia, I noticed a huge problem with the X5 rear derailleur. If I was accelerating up a slight incline (not even a hill) while standing, the derailleur would click and then proceed to click down a gear if I continued to pedal. When this happened (three times) I was clicking up a gear.
    Are X5s known to do this? If so, is there a warranty? If not, what is the best value Shimano 10 speed rear derailleur.
    I doubt that the problem is due to a defective derailleur. You might want to check the cable tension for the shifter, the behavior you describe can be caused by having excessive cable tension. The barrel adjuster at the shifter can be used to relieve some cable tension and see if that resolves the issue for you.
    Nov 2012
    Re: Problems with X5
    Yep. There a ton of YouTube videos on rear derailleur adjustment.
    Kitty! Kitty! Kitty!
    Reputation: GelatiCruiser's Avatar
    Oct 2012
    Take it to the shop and have it tuned?
    Jun 2012
    Yeah if it's new most shops offer one or two free tune ups as cables stretch and get worked in.
    Giant XTC 2 29er
    KHS Flagstaff 29er FS
    Neon Bow Trials Bike
    Norco Fluid 9.2 29er FS
    Norco BIGFOOT FATTY
  1. Even I have problems with this
    By LMN in forum 29er Bikes
    Last Post: 01-04-2012, 11:12 PM
  2. 142+ problems?
    By dirtT in forum Specialized
    Last Post: 11-24-2011, 02:09 PM
  3. 200mm cranks,drive problems,endow problems
    By Realslowww in forum Clydesdales/Tall Riders
    Last Post: 10-19-2011, 04:11 PM
  4. 2x9 problems!
    By PerthMTB in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-28-2011, 08:25 AM
  5. 2x9 set up problems
    By cabbgage in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-05-2011, 10:42 AM
