Results 1 to 30 of 30
    Jul 2013
    presta valve chuck for air compressor
    I can't get my 29'er tubeless rear tire to re-seal after a flat. I saw a bike mechanic's set-up and he had a presta valve chuck attached to his air compressor. I asked where I could buy one and he didn't know. I guess he wants me to bring the tire to him to fix. Anyone have any ideas about this? I've checked on-line and can't find what he has.
    Reputation: sgtjim57's Avatar
    I purchased a brass fitting that screws on to the Presta valve but for the life of me I can not remember where I got it. Might have been ***** Sporting Goods. I've used it once, it worked.
    2017 Cannondale Scalpel Si Carbon 3 (27.5)
    Jul 2013
    Thanks! I think I have what you are talking about. My problem is that I need to remove the core of the presta valve to allow more air in to set the bead of the tire. My air compressor only has a chuck that fits shraeder valves.
    I have this one, works very well:
    http://www.prestaflator.com/
    The other popular one is the air bob.
    Sent from my iPhone using Tapatalk 2
    presta valve adapter
    I use this with my standard schrader valve filler I purchased at the wal mart
    Reputation: Nater's Avatar
    Park makes one too.
    Park Tool Co. » INF-1 : Shop Inflator : Hand Pumps
    I made one of my own using this fitting that came with my compressor and using the end of a pump hose that I had lying around and a hose clamp.
    Oct 2012
    Just use the above listed presta to schrader adapter. You will get plenty of air flow even with the valve core in place. It's the method I use and I've never had a problem. Plus, presta chucks are ~$50 and an adapter is about a buck.
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    Quote Originally Posted by sgtjim57 View Post
    Use one of these^^^^^^^
    with one of these (ball foot chuck):
    Air Compressors & Tools | Blow Guns & Air Nozzles | 1/4" Female Ball Foot Air Chuck | 634174 - GlobalIndustrial.com
    These look like they would flow gobs of air, but they dont:
    Air Compressors & Tools | Blow Guns & Air Nozzles | Legacy™ Straight-On Tapered Chuck Inflator, 12In. Hose, Brass Indicator | B644238 - GlobalIndustrial.com
    Just thread the adapter on barely enough to seal and it wont try to unscrew the valve core from the stem. Works great.
    Jul 2013
    I have these attachments. I think the one with the trigger might work best.
    Thanks! I'll post what ends up working.
    Jul 2013
    Will this work with the core removed from the presta valve?
    Quote Originally Posted by zerokoo149 View Post
    Presta Air Compressor Bicycle Inflator, fits both Presta and Schrader - Prestaflator.com
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    Quote Originally Posted by Nater View Post
    I did this... cut the head off an old pump that was trashed and plugged it onto an air gun (pictured above).
    If I'm setting up a new tubeless install I usually take the core out, in which case you can just use that black rubber cone thing.
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
    WillWorkForTrail
    Jun 2012
    Amazon.com: Alloy Chuck 25.0 Presta Valve Super Pista Floor Pumps for Disk Wheels: Sports & Outdoors
    That has been my solution. It worked well once I got it sorted out. My review is on the product page.
    Jul 2013
    presta valve adaptor for air compressor problem solved
    I finally got what I needed to solve this problem. I think it may be just like the prestaflator product, but I couldn't get an answer concerning whether the air would flow with the core removed from the presta valve.
    Anyway, below are the photos and it works great.
    Thanks for the replies!
    Attached Thumbnails Attached Thumbnails presta valve chuck for air compressor-presta-valve-002.jpg
    Quote Originally Posted by rmoore View Post
    That's a good setup. I have the Prestaflator. I really hated the crappy head that they put on it (the same as your Silca connector) so i wound up picking up a universal presta connector:
    Amazon.com: Topeak SmartHead Bicycle Floor Pump Upgrade Kit: Sports & Outdoors
    If you get tired of smashing your hand into the brake rotor trying to remove the Silca connector, it's an easy upgrade.
    Jul 2013
    Thanks. Yeah, I noticed when I used it that I had to use some force to get it disconnected. I'm just happy it does what it's supposed to do. My bike mechanic wouldn't tell me where to get a set-up like this. I guess he wanted me to continue coming in to have my tubeless tires set.
    Bandit 29 FTW!!!
    Reputation: In-Yo-Grill's Avatar
    I've got one that I bought from my LBS. I'll take a pic of it tonight.
    Let's make like a Bike and get the Huck outta here...
    Before i got mine i asked around at a few shops. A couple of guys honestly couldn't tell me where to get something similar...finally one shop told me they paid a couple hundred bucks for their "professional" presta inflator gun. I think there just aren't many options out there!
    The silca connector works just fine! It has its quirks. When you get tired of it, there are upgrade options
    Jul 2013
    You're right. I finally had a bike mechanic tell me that I could get a presta chuck like his for $150. I paid $22 for the one I'm using, and it works fine.
    Thanks.
    Captain Calico Jack
    Reputation: Tha Dawg Catcher's Avatar
    The park tool one is definitely not the most robust one. The shop I work in has two that need constant relubing and babying to keep them functional. Called Park asked them why the valve always gets stuck or leaks, response was to service it regularly. For a shop quality tool needing to be serviced every 3-4 days and seals/grommets replaced i went back to using a normal auto style chuck with the adapter.
    DFMBA.org
    Reputation: MTBeing's Avatar
    I use this with a Schrader adapter and it works great, with one minor alteration: I unscrewed the brass grabber tip and removed the check valve that's inside floating around. This allows for two things: (1) Higher flow through the hose and (2) actual system (tire) pressure on the gauge.
    Please donate to IMBA or your local IMBA chapter. It's trail karma.
    Reputation: TwoNin9r's Avatar
    Jan 2011
    didn't read the beginning of this thread but the 3 or 4 LBS around me have a little bin of them on the counter.
    Sep 2014
    Hello Rmoore:
    What is the piece you used in-between the chuck and the hose?
    Reputation: vin1978's Avatar
    I just put this one together for just under $30.00. Used a Harbor Freight nozzle and a leyzene chuck and hose. The hose was a little tight to fit over the barbs on the adapter, but I heated it up a bit with a lighter and presto.
    used to be RipRoar
    Reputation: TraxFactory's Avatar
    Sep 1999
    I think the high volume inflator's are great but in a pinch just take a few minutes and work your way around the tire pulling the sidewall onto the edge of the rim. You can blast that thing on with lower volume....
    Reputation: supersedona's Avatar
    Dec 2012
    I made one with a stub hose from a Park floor pump dual head and a harbor freight filler. Not the needle type, just the gas station plunger kind. It's nice to have it clip on but still get trigger, plus it doesn't need a valve core to activate.
    '93 Giant Sedona ATX custom
    '93 Giant Sedona AtX aero-edition
    '73 Schwinn Suburban
    '95 Fuji Suncrest
    Jan 2015
    California Air Tools CAT-10020 Ultra Quiet and Oil-Free 2.0 HP 10.0-Gallon Steel Tank Air Compressor is the best brand portable air compressor.. It is having 10.0 Gallon Steel Tank with Wheels.. It is very well made and extremely quiet. This is far by the small air compressor I have ever used.
    Reputation: darth biker's Avatar
    Has anyone had issues with the presta adaptor where it somehow hold the core down and lets the air out? I had it happen on one tire last night. I'd inflate with the compressor, then rush to take the adapter off, but it'd be flat already... Ended up using my floor pump...
    Oct 2011
    Cut the tip off a presta valve cap. free.
  1. Presta Valve inflation with an Air Compressor
    By campybike in forum Tooltime
    Last Post: 07-08-2014, 03:03 PM
  2. presta valve adaptor for air compressor?
    By rmoore in forum Tooltime
    Last Post: 08-01-2013, 08:45 AM
  3. compressor chuck for seating tubless tires
    By mjduct in forum Wheels and Tires
    Last Post: 01-26-2013, 12:38 PM
  4. Air compressor vs Presta Valve...
    By FB296 in forum Wheels and Tires
    Last Post: 01-24-2013, 02:15 PM
  5. Brain Cramp - Presta Chuck
    By RSWMTB in forum Tooltime
    Last Post: 08-26-2011, 07:35 PM
Members who have read this thread: 72
