Originally Posted by awai04
I've heard that running a Lefty fork requires at least a 90mm length stem to keep the handlebar from colliding with the fork. Given the statement, will an inverted 10 degree 90mm stem still work with the Lefty? Thanks.
I think it will be fine.
My RX29er has a 110mm stem, and it has inches of clearance between the top of the fork and the bar. I can go measure, but it's plenty. I think if you ran 70mm or shorter you might get into the ballpark of being in trouble. I run my fork slammed down as far as it will go in the P321 clamps to reduce effective A to C, so the top of the Lefty Max 140 sticks up a bit. Pardon the bad tape job.
Here's a pic for perspective with a 110mm -7 degree stem:
*edit*
Is this Alex? Dude. You've seen my bike. Just do it, man! ... or, if you wanna try out a 70mm stem with a regular bar on my bike, come on over and we'll bolt it up and try it out. I think we could figure it out for sure in like 3 minutes.
