Results 1 to 14 of 14
    Mar 2013
    Please recommend a durable 10 speed
    I have two broken 10 speed chain for past 3 months both are kmc-sl
    are they any kmc chain that are more durable than tv so version, also what do you think about sram 10 speed chain?
    KMC X10 93.
    KMC X10.93 10 Speed Chain
    Sram chain didn't have as much longevity in published tests in a German mag.
    Mar 2013
    Is that stronger than the sl version?
    I haven't broken it. And it has solid plates. But what are you doing when your chains break? Are you certain you haven't cut them too short? I shift under some but not full pedaling tension when climbing. Technique impacts chain breakage.
    Mar 2013
    The 1st time I broke the chain I was pedalling hard downhill, while the 2nd time I broke the chain which is 2 days ago I was pedalling uphill. I end up walking 15km to get back to my car.
    The lbs are the one who installed the chain, but this time I will do it myself.
    Never trust a fart
    Reputation: frdfandc's Avatar
    Kind a hard for a shop to screw up a KMC chain install considering they use master links. The only chains I have seen fail due to installation error are Shimano chains when the Shimano pins are used instead of a master link.
    One chain breaking, I'd chalk it up to crap happens. 2 chains breaking in a short time period I'd suspect rider technique is a possible cause for chain breakage.
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    the chains may have been too short.
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
    Never trust a fart
    Quote Originally Posted by meltingfeather View Post
    That's a possibility for sure, but I have my doubts since it happened with him going downhill as well.
    Who knows for sure.
    May 2012
    The sl version is not stronger than the lower priced ones, just lighter and better coating, hence more expensive
    Jun 2012
    I wiegh 220 and have not broken a sram chain and I shift when ever loaded or not. I find them extemely tough. I will ot buy any chain with hollow this and that just making it to weak.
    Giant XTC 2 29er
    KHS Flagstaff 29er FS
    Neon Bow Trials Bike
    Norco Fluid 9.2 29er FS
    Norco BIGFOOT FATTY
    I Ride Bikes
    Reputation: Mazukea's Avatar
    I like my SRAM chains. I would suggest getting some Quick-links/Power Chain connectors and a Master Link plier and throw it in your backpack. So you can fix your chain on the trail instead of walking 15km back to your car.
    I like to hug trees at FULL SPEED!
    INSTAGRAM -> hawaii808MTB
    FACEBOOK -> Big Island Mountain Biking
    Plays with tools
    Reputation: customfab's Avatar
    I'd suggest giving a Shimano chain a try.
    Quote Originally Posted by frdfandc View Post
    Who knows for sure.
    He said he was pedaling hard downhill, meaning the chain was under tension. Suspension can compress and cause chain growth (depending on suspension design) in either case, putting large peak loads on the chain.
    I weigh over 200 lbs and have ridden kmc sl chains for at least the last 5 years, including on my SS, and never broken one. I even have one with two missing links in it.
    Doesn't mean it wasn't the chain, just sayin.
    There's a chain test chart floating around that i couldn't quite find, but here's a similar one:
    http://www.connexchain.com/data-live...ier_080306.pdf
    Naturally the brand doing the testing came out on top, go figure... The one i saw also had KMC chains in the mix, and they were solidly in the middle. SRAM was at the way bottom and Shimano didn't do much better.
    So i run the KMC 10.93--$22 shipped on Amazon, they seem to last a long time, and they shift great.
  1. I need a durable 9 speed cassette
    By asetliff in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-13-2011, 05:55 AM
  2. Alfine 8-speed hub: which finish is more durable?
    By anga in forum Internal Gear Hubs
    Last Post: 08-23-2011, 11:43 AM
  3. Replies: 13
    Last Post: 07-25-2011, 06:11 PM
  4. Replies: 9
    Last Post: 07-25-2011, 01:29 PM
  5. Most durable 9 speed drivetrain
    By sagealmighty in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-11-2011, 08:39 AM
