Results 1 to 5 of 5
    PF30 Bottom Bracket which one?
    I'm planning to buy Salsa Spearfish which requires a PF30 type Bottom Bracket. I have no experience of these so I 'd like to hear your experience of them. Are they running them reliably with problem-free operation? Which is the best unit?
    Are you looking to run 30mm cranks or 24mm? I'm not sure you have a lot of choices out there if you're looking to run 30mm. Just go with the SRAM. If 24mm, I recommend the one from Praxis.
    EDIT: As for personal experience, I've been using 24mm cranks in a Spearfish. I've had less than stellar success using the PF30 BB with adapters and the Truvativ threaded adapter shell. I've only got a handful of rides on the Praxis, but it's the first solution I've seen that actually looks well engineered for the application.
    Ah I can see I need some more education on this topic. I had originally hoped to put my XT 10-speed cranks on with an adaptor but I heard that's not a great solution. Tell me more about the praxis and the crank options available.
    Cheers, Tim.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Tea@Dimbola View Post
    Cheers, Tim.
    If you want to use the XT crank, just get the Praxis BB and be done with it.
    Praxis Works | Conversion Kit
    mtbtires.com
    Cheers, Tim.
    In that case, the Praxis adapter is the only thing I can recommend. I had poor experiences with all of the other adapter options. It's not cheap, but I spent 2x as much trying adapters before buying the Praxis. It's made to work with Shimano cranks so that'll get you what you want.
    BB30 Conversion Kit BB - 73mm
