Results 1 to 6 of 6
Thread: Pedal noise?
    Reputation: OllieQ's Avatar
    Jun 2013
    Pedal noise?
    Alright quick question.
    Does any body else have an insanely loud pedal? I just want to know if its normal before I go buy more pedals.
    Right now I have the 'Kona Wah Wah'.. and oh my.. Every pedal stroke results in a loud ' TING!' .. drives me banana sandwich!
    Reputation: bigkat273's Avatar
    Re: Pedal noise?
    Maybe a little dragging noise if seals or bearings are worn is normal but loud sharp noises are bad.
    Jun 2013
    Ok good to know.. because they are literally off the shelf new.. Maaaaybe seen 10km with em..
    Re: Pedal noise?
    They might just need some more break in time... Give them some more miles before dropping coin.
    Are you sure it's the pedal making the noise? I ask, because often weird noises on bikes come from places other than where you suspect. If you are sure it's the pedal, removing the pedal and greasing up the threads and retightening may help.
    Dec 2011
    Similar problem for me before and it was a result of a missing pedal spindle washer. It was my fault, but I have seen LBS forget this step before too. Not all pedals/ crank arms require washers, but the ones that do require the washer installation for proper noiseless function. In my case it was Time pedals on a Shimano crankset.
  1. Replies: 2
    Last Post: 06-13-2013, 07:41 PM
  2. Noise coming from my left pedal/crank area
    By Sickmak90 in forum General Discussion
    Last Post: 06-21-2012, 03:31 PM
  3. pedal fast to minimize muscle ache instead pedal slow?
    By Picard in forum General Discussion
    Last Post: 11-03-2011, 08:51 PM
  4. bike makes a clicking noise when pedal
    By akacoke in forum Beginner's Corner
    Last Post: 10-29-2011, 07:58 PM
  5. Replies: 15
    Last Post: 06-14-2011, 05:18 AM
