Results 1 to 8 of 8
    Sep 2012
    Parts list to build a 29er?
    Hi, does anyone know a website or have a list of the basic parts i'd need to build a 29er from the ground up? Thanks
    Reputation: 4nbstd's Avatar
    Handle bar
    Brake levers
    Grips (and grip plugs)
    Front/Rear brakes/rotors
    Cable & housing
    Shifters
    Front/rear derailleurs
    Cable & housing
    Stem
    Headset
    Frame
    Fork
    Front/rear wheels
    Tires
    Quick releases and/or bolts
    Saddle
    Seatpost
    Seatpost clamp
    Crankset (and bottom bracket)
    Pedals
    Chain
    and most important part on any bike... TURBO SPOKE!
    <object width="560" height="315"><param name="movie" value="http://www.youtube.com/v/CDafMzo4HO8?version=3&amp;hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/CDafMzo4HO8?version=3&amp;hl=en_US" type="application/x-shockwave-flash" width="560" height="315" allowscriptaccess="always" allowfullscreen="true"></embed></object>
    Ghisallo Wheels
    I'm really good looking.
    Sep 2012
    Thank you, but i forgot to mention that i wanted to make a single speed.
    Quote Originally Posted by theewoodsman View Post
    Take away shifters and derailleurs, and get the rear wheel with single speed hub or regular hub with single speed spacer kit. And a cog.
    What's your budget?
    Ghisallo Wheels
    Sep 2012
    Well, i want to save up for a good 29er, but am trying to build or buy a cheaper one for now under 350 becuase i wrecked my previous bike.
    Building a full bike with $350 will be almost impossible unless you have a lot of extra parts salvaged from last bike and get a used frame for cheap.
    On the other hand, you can get Bullseye for $400. Mountain Bikes - 29er SingleSpeed - Dawes Deadeye
    Gravit 29 is $350 Save up to 60% off new Mountain Bikes - MTB - Gravity 29 SS Single Speed 29er Mountain Bikes, but personally, I would go for Bullseye solely based on the fact that its frame is steel and Gravity is aluminum.
    I have no experience with any bikes from bikesdirect though, but a lot of people here have bought from them, and they seem satisfied.
    Ghisallo Wheels
    Reputation: connolm's Avatar
    Another list - should be similar to one above:
    Frame
    Handle bar
    grips
    brake levers
    bar end caps
    stem
    spacers
    headset/star-nut
    fork
    crankset
    chainring
    single-speed chainring bolts (yes, they're specific and different from geared chainring bolts)
    bottom bracket
    chain
    rear cog
    single speed spacers (if you buy regular wheels)
    chain tensioning system (if no horizontal droupouts)
    Wheelset (rims, spokes, nipples, hubs, rim tape, quick release axle-F, lock on axle-R)
    Brakes and calipers
    Brake cables and housing
    tires
    tubes
    seapost
    saddle
    seatpost clamp
    pedals
    zip ties (for cable routing)
    Tools necessary to do the job right:
    Hex wrench set
    lube
    torque wrench
    bottom bracket tool
    cassette lockring tool (??)
    crown race setter
    headset clamping tool
    hack saw (for shortening fork steerer tube)
    chain tool
    wire cutter (for brake a cables)
    tire pump
    tire levers for putting tires on
    i want one of the turbo spokes...thats cool, way better than playing cards!!!
