Results 1 to 20 of 20
    Reputation: rob1035's Avatar
    P35 + Ardent 2.4 = ???
    I love my ardents, especially up front. Thinking about going with a nice wide rim, and I'm curious if anyone else is running this combo and how it is. How wide is the tire casing/tread? Currently on Crests so it would be a huge change, rim width wise.
    Rob
    Did I catch a niner+?
    Not on a P35 but have run a 2.4 on my Gordo and it balloons up pretty damn big and requires some serious clearance on the rear if you plan to do it. As for actual numbers no clue but it really is damn big.
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Quote Originally Posted by rob1035 View Post
    Rob
    Ardent on a P35 is massive, and with a really square profile. If that's your thing (I love it, some don't) they are hard to beat, and surprisingly light for the width.
    RIDE TO LIVE
    Reputation: LIV2RYD's Avatar
    I'd love to see a Knard 3.0 on a P35. I bet that would be a sick combo.
    Harmonius Wrench
    Reputation: Guitar Ted's Avatar
    I've got that combo on this '07 El Mar. The Ardents are tubeless and go about 61mm casing width at lowish pressures. (20-ish psi)
    Riden' an Smilin'
    Guitar Ted
    Blog
    RidingGravel.com
    Reputation: Gasp4Air's Avatar
    I ran Ardent 2.4s soft and tubeless on Flows (28mm) and they were a full 2.4-2.5 and pretty tall. I imagine the would get wider (and shorter) on 35mm rims.
    Use it, use it, use it while you still have it.
    I run Ardent 2.4s on P35 rims on my HiFi. They come up to right about 62mm at the widest point. That is set up (ghetto) tubeless at 24psi. They were at 60mm when I first set them up, so they have grown a bit with time. My experience is that it is an excellent combo.
    Dec 2009
    Rob
    You may find Flow ex has more effect with it's lower sidewall. I find tires on a crest not far off a P35 whereas they are normally 2mm wider on a p35 than say a Blunt.
    Dec 2009
    Quote Originally Posted by Gasp4Air View Post
    They get wider, squarer profile and about 1mm taller on a P 35. That shorter on wider rims thing is a myth.
    Reputation: stremf's Avatar
    Dec 2012
    I've got a Blunt 35 (formerly known as P-35) ready to be laced up, but I'm waiting to see if the Rabbit Hole rim will be available soon. I'll be using Ardent 2.4's on either rim. Thanks for posting the pictures.
    Harmonius Wrench
    Quote Originally Posted by stremf View Post
    Rabbit Holes or possibly the new Velocity rim that is coming this year. (Think similar to Rabbit Hole, but in more ano colors)
    Riden' an Smilin'
    Guitar Ted
    Blog
    RidingGravel.com
    miwuksurfer
    Guest
    N/a
    Dec 2012
    Quote Originally Posted by Guitar Ted View Post
    Have you been privy to any specifics? Weight, dimensions, etc? Velocity products have been solid for me and I'm glad there will be alternatives to the Rabbit Hole.
    Quote Originally Posted by gvs_nz View Post
    Interesting point, I was looking solely at the inner width dimensions, and hadn't really given Stan's "lower sidewall=wider tire" claims any thought...
    Aug 2003
    This is true.
    This is a big stretch.
    Ride On
    Reputation: geraldooka's Avatar
    Relevant thread resurrection.
    Hi Folks,
    I'm wondering for those who have moved from a Flow type rim (approx. 23mm inner width) to one of these wider rims (approx. 28-29 inner width). What do you think? Are they fantastic? Meh? Never look back at skinny again etc.
    I'm debating new wheels now, LB Carbon, Syntace W35, others...
    Michael
    Ride on!
    FWIW, I have a wheelset with a P35 front coming, so I'll have some actual info soon (only a year and 4 months later...)
    Reputation: CCSS's Avatar
    Here's an Ardent 2.4 on a P35 on the back of my Black Cat...
    And Here's the Minion 2.5 on the front...
    Thanks to @mikesee for steering me in this direction. It rocks.
    The difference between an Ardent 2.4" on a Flow (non-EX) and P35, both tubeless at similar pressures, is minimal. The casing on the P35 is just barely wider (3mm or so). I haven't had it on the trail yet, where the true difference will probably show.
