    MJ1
    MJ1 is offline
    Optimum rim width for XC 2.25 tires
    I have posed this question in a couple of different formats but I will try again to get a definitive answer (if that's possible on a forum!). For general XC trail and race, with a 2.25 tire front and rear, what is the best ID for a rim? LB rims at 23mm, Rovals at 22mm, or Derby at 29mm? I'm not a heavy-weight at 160 lbs but I want a wheelset that will help me in the corners and downhills. Help me please!
    Reputation: pablobell's Avatar
    Oct 2013
    Most XC bikes with 2.25 tires seem to come with 19mm rims so I would say 22/23 would be a nice upgrade, I would say over 25 is probably not giving you any additional benefit.
    To the Point: Bill Shook on Wheels and Wide Rims - Pinkbike
    From the interview--
    " Where do you imagine the width of mountain bike rims and tires will end up, once tire makers join up with the concept?
    First off and most obvious, the tires need to fit through the frame. I don't think there is one ideal size for all applications. For cross-country racing, the ideal size is a 32-millimeter-wide rim like my Wide Lightning. I chose 32 millimeters after watching our pro riders in the US and Europe over the years. I started these riders with rim widths at 24 millimeters wide, then 26 millimeters, each with reductions in tire casing size and weight, Then I tried 28 millimeters with a subsequent reduction of tire casing size and weight. In watching this progression, I saw that the profile of the tire on the rim (as a unit) was going more and more towards a half-circle shape (hemispherical tire profile). I took it to its conclusion and the sweet spot is at 32 millimeters wide, as it is the maximum lightest casing with the best tire profile. If you go beyond that to, say, 36 millimeters wide, you get negative returns, because the shape of the tire on the rim exceeds the optimum hemispherical shape."
    Always Learning
    Reputation: BruceBrown's Avatar
    Quote Originally Posted by MJ1 View Post
    ID of 21-23mm
  1. Arch EX HELP - hub/width/tires?
    By donn12 in forum 29er Components
    Last Post: 03-14-2013, 06:23 PM
  2. How does C width translate to inch width in tires?
    By aBicycle in forum General Discussion
    Last Post: 08-03-2012, 11:44 AM
  3. Replies: 3
    Last Post: 02-17-2012, 08:49 AM
  4. Are Schwalbe Tires True to Width?
    By surlyduck in forum Wheels and Tires
    Last Post: 12-28-2011, 08:23 AM
  5. Hookworm (urban tires) and rim width...
    By redline814 in forum Fat bikes
    Last Post: 02-13-2011, 12:46 AM
Members who have read this thread: 8
