    Oct 2013
    Noob question about fork upgrade
    Hey guys,
    I'm looking to upgrade the awful stock fork on my 2013 DiamondBack Overdrive, and was a little worried about one thing.
    The website shows the Fork offset as 38 mm, and I was looking at upgrading to either the recon, the reba, or tower pro. I know the tower pro is a 48mm offset, will that make a huge difference?
    I am also considering the Raidon through the loyalty program brand new instead of picking up a deal on a used reba, recon or tower, what are your opinions on that?
    Thanks for your help guys.
    Reputation: Pauldotcom's Avatar
    Aug 2010
    Check out this thread
    What is "fork offset" all about?
    “People fear death even more than pain. It's strange that they fear death. Life hurts a lot more than death." JM
    More offset is turning out to be better for 29ers. Ibis and others using the new Pike and Fox forks are choosing 51mm offset. Trek uses 51mm on all 29ers. It will quicken steering a small amount.
    If you use a Tower Pro(48mm) or Reba(46) you will drop more weight off the front 3.5-3.8lbs vs 5lbs for the Raidon and 5.8lbs for the X series Suntour on your bike.
    Oct 2013
    Thanks for the reply and links. As a beginning mountain biker, it's almost as if I'm reading Hieroglyphics...lol.
    Some people say that the higher offset is a good thing for a 29er, while others say that changing the fork to have a higher offset can be bad for the bike as it's not within the current bike's geometry. In laymans terms, would ANY of the forks I listed be better than the other for my CURRENT frame BECAUSE of offset?
    Thanks for bearing with me.
  1. Noob Question, Upgrade handlebar on Schwinn Sidewinder?
    By tomtom123 in forum Beginner's Corner
    Last Post: 09-25-2013, 10:02 AM
  2. Fork upgrade? Noob question before purchasing
    By absoluteczech in forum Shocks and Suspension
    Last Post: 10-26-2011, 08:16 AM
  3. Noob MB fork question....
    By EnEcosse in forum Clydesdales/Tall Riders
    Last Post: 03-31-2011, 10:22 AM
  4. noob with a fork question
    By 918biker in forum Shocks and Suspension
    Last Post: 02-28-2011, 06:02 PM
  5. noob with a fork question
    Last Post: 02-27-2011, 11:17 PM
