    Jun 2013
    Newbie front shock question
    2 Part question for you guys about the front shock.
    The suntour xctv3 fork that came on this bike is really a piece of garbage in my opinion. When I stand up and try to crank on the bike to go up steep hills the front shock is like a pogo stick. There is no way to lock it out and I THINK it is set to its stiffest position. Anyone else have this problem?
    If it cant be fixed I was thinking I will probably have to get a new front fork to replace it. I have read on here that a brand x fusion shox is pretty good for the money. Anyone have any opinions if they are any good or not and if you have one which model do you have or suggest. Dont want to spend much more than 300.
    The bike is a DB response xe 29, thanks
    Apr 2013
    Rock shox recon silver, 100mm, solo air..lockout. Great fork for under 300. Just google it. I think i payed 250
    Apr 2013
    Your suntour is a spring fork. The over simplified answer is yes its normal for a cheap spring fork to feel bouncy, even with the rebound adjustments.
    Suntour who designed this fork say it is for bike paths and easy riding only.
    Nick at Suntour has an upgrade programs for people who own one.
    Riadon 5lb air fork for 189+10ship.
    If you want to upgrade your Suntour fork
  1. Newbie Question.....Rear Shock Compression Ratio?
    By BigJZ74 in forum Shocks and Suspension
    Last Post: 07-06-2015, 03:42 PM
  2. Newbie front der adjusting
    By swl7 in forum Beginner's Corner
    Last Post: 09-10-2012, 02:02 PM
  3. Replies: 1
    Last Post: 09-06-2012, 08:35 PM
  4. shock settings for newbie
    By jrs67 in forum Giant
    Last Post: 08-18-2011, 11:17 AM
  5. Newbie with some front derailleur ?'s
    By rlouder in forum Beginner's Corner
    Last Post: 06-08-2011, 04:59 PM
